04-05-2012, 08:20 AM   #16
As the discussion seems to be veering more towards using IR remote I thought I'd share an idea that I've come up with in regards to impractical placement of IR receiver on the camera.
When my IR remote will finally arrive I will attempt to make an omnidirectional IR receiver reflector from a piece of clear lexan rod and some tin foil. The rod would have a cone shaped concave on top that's lined with tin foil to reflect the IR signal down through the lexan rod and then via 45 degree mirror at the bottom into the IR receiver. Hopefully that would give me 360 degree angle reception for IR.
04-05-2012, 09:45 AM   #17
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
...and I am still working on a wired remote release. I just got another cheap IR remote in the mail. I will re-attempt my modification to put an external switch in parallel to the rubber dome switch built in to the remote. The remote's circuit board does have what appears to be solder pads for such a switch. I just need to practice my tack soldering skills - I haven't done fine work like this since I owned and modified my Atari 8-bit computer - and not to mention I need reading glasses these days for close work <sigh>.
I can make the externally wired switch of any practical length - 6m seems plenty long for my first try. I have already verified that I can trigger the camera's IR receiver when the remote is at 90 degrees and immediately below or above the receiver, so a matching pair of Velcro patches will attach the remote to the camera. A simple reflector/hood attached to the remote and between the remote and the IR receiver should also make sure it works well even in direct sunlight.
battery, camera, control, k-r, kr, pentax k-r, pk, tether, usb
PENTAX Waterproof Remote Control O-RC1 vs. Remote Control F jpzk Pentax Camera and Field Accessories 8 12-02-2013 08:11 AM
K-x remote control Gary G Pentax DSLR Discussion 22 01-02-2011 09:50 AM
Remote control F Mojtala Pentax Camera and Field Accessories 2 11-02-2010 03:58 PM
Remote control for Pentax: PocketPC app. (alternate to Pentax remote) dragonfly Troubleshooting and Beginner Help 4 08-12-2010 10:22 AM
K-x - looking for remote control patsyd Pentax DSLR Discussion 17 02-26-2010 09:49 AM
All times are GMT -7. The time now is 01:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
