Originally posted by ofer4 mpmetro, are you sure? I just tried using AF-C, and I still get the double flip. In fact, as Anvh stated, I get a double flip even in manual focus.
If you are using Contrast Detect AF, then it doesnt matter if its AF-C, AF-S, or AF-A. Because in contrast detect, after it has locked focus, the live-view stays on, then you press the shutter fully and the double flip happens
But if you change the focus to Phase Detect for liveview and use AF-C, then when you press the shutter half-way, the screen will go blank, lock focus, and the screen will stay blank. Then the double flip should not happen
The only reason the double flip happens is because live-view is on right before the actual shot is taken, so the the camera has to do the double flip to turn off liveview, take the shot, the turn live-view back on. It doesnt really have to do with the Focus settings, but the focus settings determine if live-view will be on right before the actual shot is taken or not.
here is a quick video i made showing it on my kx
