01-27-2012, 10:49 AM   #1
Macro setting LV focusing question
I'm a bit perplexed...when I use my macro lens on live view, it zooms way in on the object than goes back out...is this normal?
01-27-2012, 10:53 AM   #2
Auto-focusing
01-27-2012, 11:02 AM   #3
JinDesu's Avatar
Are you using autofocus? Are you a little bit too close to your object for even the tiny minimum range to work on a macro lens?
01-27-2012, 12:36 PM   #4
You should generally use manual focus for macro, or manually get the lens close to achieving lock and then use AF to perfect it.
If you do rely on AF, you'll frequently see your lens hunt, unfortunately- though it does depend on the shooting conditions.
01-27-2012, 12:43 PM   #5
I've noticed that LV-AF on the K-5 will often lock onto a completely wrong focus (not even close -- just locks onto a total blur) rather than continuous hunting, although it does it a hell of lot faster than the K-7 so it has that going for it...
01-27-2012, 01:46 PM   #6
Anvh's Avatar
With phase AF the camera will keep trying but with contrast is just goes through the focus range and if it couldn't find anything to lock on it simply stops.
01-27-2012, 01:49 PM   #7
QuoteOriginally posted by Anvh Quote
Yes, exactly. Unfortunately this means you can't really trust it because it isn't always obvious whether it really locked onto something or not, so you end up using the digital zoom to check it. Almost always end of manually focusing in LV...
01-27-2012, 03:33 PM   #8
Anvh's Avatar
I need to test it but i believe it stops at either end of the focus range so that wouldn't be that hard to spot if out of focus or not
Also it gives an focus confirmation if it locks on you know.
01-27-2012, 04:23 PM   #9
Mine seems to beep like it has focused on something no matter what. Often just a blur though.
01-27-2012, 04:28 PM   #10
JinDesu's Avatar
If it's live view, it should be contrast detect right? Maybe often times, even though it's a blur, the contrast detect system actually found a solid line of contrast in the blur...
01-27-2012, 04:36 PM   #11
I'll have to play with it some more, but sometimes it seems to lock on and is just totally unfocused -- possibly this is actually not locking on but is just stopping one one end or another of the range as suggested. Other times it locks onto something and ALMOST achieves sharp focus but not quite -- it seems like it should do a little more hunting here and it would be ok but it just stops. And other times it nails it and is completely on.
Are the ultimate results on the K-5 the same as on the K-7 except faster? The K-7 is SO slow in LV that I never really had the patience to bother with it -- I'd either use manual or would use the normal AF. I was excited to see the K-5 go so fast, but it doesn't nail it often enough...
01-27-2012, 04:42 PM   #12
Anvh's Avatar
Not with the K5 just tested it.
Focus lock = beep + green focus square
no lock = no beep + red square
01-27-2012, 04:49 PM   #13
I will investigate further, thanks.
01-28-2012, 10:42 AM   #14
Thanks guys!
camera, k-r, kr, macro, pentax k-r
K10 Setting Question Deiberson Troubleshooting and Beginner Help 7 01-25-2011 10:34 AM
Best setting for focusing Gerrys Troubleshooting and Beginner Help 12 01-05-2011 12:08 PM
Setting Exposure Question lyunya Troubleshooting and Beginner Help 7 12-21-2010 01:48 PM
Question regarding Av setting and manual lenses- newer gen bodies virgilr Pentax DSLR Discussion 8 10-03-2010 04:09 PM
K7 Macro setting Paulc1964au Pentax DSLR Discussion 9 02-24-2010 04:37 AM
All times are GMT -7. The time now is 12:14 PM. | See also: NikonForums.com, part of our network of photo forums!
