02-09-2012, 10:16 AM   #16
mtroute's Avatar
QuoteOriginally posted by S3rgio Quote
Ok, but i mesured on the Vivitar 2800 153 volts !
About what others mesured on: Photo Strobe Trigger Voltages
On Cowboystudio web site it says:
"Other flash models with a trigger voltage of 12V or lower"
Yeah I probably wouldn't put that on my camera or the triggers...Not sure what your options are with that strobe other than forcing true manual flash mode on your camera.
02-09-2012, 11:01 AM   #17
jase036's Avatar
When using high voltage old flashes and strobes, the best solution is to use a Wein Safe-Sync adapter that will drop the voltage to below 6V
you can check get it from BH here.
02-09-2012, 01:29 PM   #18
Anvh's Avatar
QuoteOriginally posted by mtroute Quote
Cactus V5 can trigger those easily, it's rated up to 300 volt
06-13-2012, 10:32 AM   #19
I'm looking to get some cactus triggers to go with my K-R and Metz 50. However, I'm still confused a bit by all the modes and want to understand the advantages. Are these the main benefits of getting the cactus?
1. Better range/reliability vs K-r built in wireless mode.
2. Ability to set power manually on the Metz flash without needing to fire the onboard flash (my understanding this is because manual flash setting is available only via servo mode which uses the Metz optical sensor, which requires the Pentax onboard flash to fire).
3. Multi-channel mode (which does not iterest me too much yet).
Is there anything else here I'm missing? Any help is appreciated!
06-13-2012, 12:20 PM   #20
Anvh's Avatar
I think you got it.
Beside you can also trigger most if not all manual flashes and most studio flashes.
06-13-2012, 02:03 PM   #21
A huge thanks!
I also read something about only being able to get 1/4 power maximum (with Metz Servo mode) so I think I'm pretty much sold on the cactus v5s ... price is not too much in relation to flash, camera, lenses etc etc!!
camera, flash, k-r, kr, pentax k-r, vivitar
K-5 Continous focus in bad lighting sports example Urkeldaedalus Pentax K-5 4 12-04-2010 06:58 PM
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
Streets Garage lighting.... not too bad afterall... inneyeseakay Post Your Photos! 10 11-21-2009 12:01 PM
Bad lighting ombre Photo Critique 10 12-02-2007 11:52 AM
Portable (wireless) lighting? little laker Pentax Camera and Field Accessories 2 12-01-2006 01:13 AM
All times are GMT -7. The time now is 01:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
