03-10-2012, 08:25 PM   #16
QuoteOriginally posted by Mel C Quote
I am still struggling with this. I am trying to have it automatically imprint the date/time each pic is taken. My Cannon does this but I still haven't found the way to make the K-r do it. The date/time is even displayed when I review pics on the Cannon and it appears in the prints. Does the K-r not have this capability or am I just not understanding the instructions? Guess I need remedial instruction. Sorry.
You must be in playback mode in other words a photo must be visible on the Monitor
* On the 4 way controller press where the flash symbol is
* use the controller to select DPOF (once encircled) press OK
* Select all images if you want it to applied to all the photo's (use the controller press flash symbol to move highlight from single image to All Images)
* Press OK once highlighted
* use up or down on the controller to set the number of copies (If any are to be made)
* Use the E DIAL (either way doesn't matter) it places a check in the date block (Dial that magnifies)
*Press OK - You're done
You should now see a symbol bottom right of your monitor indicating DPOF is set.
camera, date, k-r, kr, pentax k-r, stamp, time
Plus 1 hour time stamp for Movies? I Silly Wombat Pentax K-5 4 11-05-2011 12:46 PM
DPOF setting/ time and date stamp PentaxKX-2011 Troubleshooting and Beginner Help 3 01-19-2011 09:00 AM
How to prevent Adobe DNG Converter from changing the file time stamp? raider Digital Processing, Software, and Printing 4 05-02-2010 02:05 AM
Time stamp seems to be off. K-9 Site Suggestions and Help 2 05-09-2009 09:52 PM
Optio M50 Date & Time stamp MarkC Pentax Compact Cameras 1 04-30-2009 03:30 PM
All times are GMT -7. The time now is 07:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
