02-19-2012, 03:29 AM   #1
molette pentax kr
Bonjour,
La molette de mon kr est défectueuse, quand je veux changer les valeurs (iso, f ou vitesse) elles défilent sans ordre logique, montent, descendent. Bref les réglages en mode manuel sont tres compliqué.
Avez vous dejà eu ce problème ?
Que faire ? Mon boitier a déjà un an et je n'envisage pas trop de m'en séparer 3 semaines pour un retour SAV
Merci de vos conseils
02-19-2012, 03:47 AM   #2
I don't speak French, but I machine translated your post. Hopefully you can do the same. You need to spray a small amount of contact cleaner on the dial to fix it. This happened because the dial had too much grease, but it's easy to fix. Apply a little contact cleaner to it, and then rotate the wheel for a few minutes in each direction. Repeat if needed, but avoid using too much.
Be sure to use only a clean drying contact cleaner - one that leaves no residue.
Hope this helps.
02-19-2012, 09:51 AM   #3
Thanks for you'r answer.
Where i can buy contact cleaner ?
Thank you so much !
02-19-2012, 10:01 AM   #4
QuoteOriginally posted by popt Quote
Thank you so much !
WD-40 specialist rust release penetrant will do the job,
there is many more on the market , you will be able to purchase from any good hardware store ,DIY store or automobile store.
P.S.
Remember just to use a very tiny amount of the spray!
02-19-2012, 11:37 AM   #5
philbaum's Avatar
QuoteOriginally posted by Malfunction Quote
P.S.
Definitely don't use WD-40, it leaves a grease residue behind that can really cause problems. Radio Shack in the US sells a silicon based electrical contact stuff of some kind that should be appropriate - go search electrical shops i think.
02-19-2012, 02:00 PM   #6
WD40 is about the worst thing you could use. I wouldn't suggest a silicon based lubricant either. To fix this issue you don't want a lubricant, you want a solvent - that's what a contact cleaner is. It needs to dry without any residue at all.
02-19-2012, 04:54 PM   #7
QuoteOriginally posted by Philoslothical Quote
I mentioned WD-40 "specialist" rust release penetrant,(FAST DRYING AND NO MESSY RESIDUE ) not the ordinary WD40
02-19-2012, 05:10 PM   #8
Even so, why? Why use something designed for rusty machinery when the correct product exists for cleaning electronic contacts?
If in doubt about the contact cleaner you get, test it by spraying a small amount on glass. If it leaves a noticeable residue when it dries, don't use it. You can buy the correct kind of cleaner from an electronics dealer, a computer shop maybe, or somewhere online like Ebay.
02-19-2012, 06:08 PM   #9
Its good for Arthritic knees too i hear ha ha ha
Yep your right , will be able to get something much cheaper as well
camera, k-r, kr, molette, pentax k-r
Problème avec K-X et molette de sélection Tapirashabrack Pentax DSLR Discussion 3 09-19-2010 12:54 AM
All times are GMT -7. The time now is 02:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
