Originally posted by jacamar I just checked and a white piece of paper works as a reflector with the Pentax remote from about 15 feet indoors - I'll check in brighter light sometime, maybe using tinfoil. So maybe I don't need the pclix boris.
If you find you need something a bit more sturdy, like if there's a breeze that interferes with paper, try cutting a chunk off an aluminum pie plate (the disposable type), curling it into a bit of an arc, and punching a hole for it to go on the tripod screw between it and camera. It's easier to do than explain, I think.
