Originally posted by aymonroche okay thanks, judging by this post looks like i'm much better off with AA's anyway.
There is one thing you may need to know if you are going to use AAs pack, some times the camera may show the battery is running low while it's not actually "low", especially when you are using too much flash or your lens is doing a lot of hunting (like 55-300).
I think this may be caused by the voltage of AAx4(=6v), the li-ion batt is 7.4v, so when you see the battery bar is yellow or red after not too many shots, then what you need to do is just simply turn off the camera and turn on it again, the battery bar will be green and full again.
