04-03-2012, 12:43 PM   #1
Images from K-r to PC
Please point me in the right direction to "re-transfer" an image that has been transfered from on a previous occasion.
I have transfered (Downloaded) Images from the K-r to the PC successfully by:
Method 1: K-r to PC Cable as supplied with Camera.
Method 2: By removeing the Card from the K-r and installing it in the PC.
In each case, virgin images only are transfered, none of those that have been transfered on a previous occassions
are transfered again.
I have a need for an image to re-appear on the PC that was on the PC, but unfortunately got deleted. The only place
this image appears now is on the K-r. As it has been previously transfered I cannot find a way to repeat the
transfer process. Help will be appreciated.
04-03-2012, 12:54 PM   #2
Philoslothical's Avatar
The card, or camera, will appear in Windows Explorer just like a hard drive. Just navigate into it, into the DCIM folder, find the folder with the date you want, and copy it over (or copy individual pictures from inside it). Simple stuff.
04-04-2012, 03:35 AM   #3
sterretje's Avatar
QuoteOriginally posted by Philoslothical Quote
Simple stuff.
Not if a computer is setup to make your life easy
04-04-2012, 10:04 AM   #4
Hi Philoslothical
Thanks for advice, it worked first time, 100% what I required. Cheers.
04-04-2012, 05:49 PM   #5
Glad you got it sorted out. This is the method I use every day. Most programs that import automatically get on my nerves by trying to do too much or too little.
04-04-2012, 08:37 PM   #6
RioRico's Avatar
I disable all auto-imports. I wrote a script that moves files from my various AV devices to appropriate file folders, after renaming the files as needed, like for numeric rollovers. Programs that auto-import put files where THEY want them, not where *I* want them. I still think I can outsmart most software. Am I delusional?
04-06-2012, 01:04 PM   #7
Hi Philoslothical Thanks for tip. Do you connect K-r to PC useing the convetional lead, or Is it possible to connect via Wi-Fi? If Wi-Fi is possible I would appreciate Instructions. I also agree, one cannot pick & choose when useing Auto, its out of ones hands.
Hi RioRico, I appreciate your comments which I fully agree with.
At 85 comming up I've recently upgraded to DSLR haveing transfered many of my 1980 onwards Me-Super Photo's to PC. I still have my early Sony Cyber-Shot for possible emergencie's. The Script that you wrote, is it on this site, if so, please direct me to it.
Cheers to both of you. Art.
04-06-2012, 01:37 PM   #8
I just pop out the card, stick it in a small card reader, and plug that into a USB port. I have used the cable, but the rubber cover on the cable port kinda annoys me and I didn't want to put too much wear on it.
04-06-2012, 04:10 PM   #9
RioRico's Avatar
QuoteOriginally posted by Artpart Quote
I'll post it if you wish, but be warned: It's a WinDoze .BAT batch file that's customized for my setup and dependent on some specifics. I wrote the first version about a decade ago as a .4BT script for 4Dos|4Win, then had to devolve it for the Win batch processor when those command interpreters went out of development. So the script is rather crippled, but I'm to lazy to rewrite it for any other interpreter.
04-06-2012, 08:00 PM   #10
Wheatfield's Avatar
No, but some programs (Lightroom) only work well when they are in charge of image management.
I've decided that for Lightroom to work easily, you have to let go of directory trees and trust in the keywords.
04-06-2012, 08:14 PM   #11
One of the bigger reasons I stick with an old version of Photoshop.
camera, image, images, k-r, kr, method, pc, pentax k-r
K-7 iso 3200 images: No NR, yet the faces look plastic. (11 images) pcarfan Pentax DSLR Discussion 43 08-31-2010 08:13 AM
How to see images vertical images after download as vertical ? netuser Troubleshooting and Beginner Help 8 08-28-2009 03:48 PM
A variety of images with FA* 200/4 Macro (no bugs) - VLF competition images Marc Langille Post Your Photos! 28 08-22-2008 07:28 PM
High ISO concert images with Tam 28-300 (Images) jsundin Post Your Photos! 2 07-05-2007 08:19 AM
A few K10D tourist images of Italy (9 images, about 200kb each) volosong Post Your Photos! 2 04-24-2007 04:29 AM
All times are GMT -7. The time now is 07:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
