04-11-2012, 06:46 PM   #1
K-r Failed to Record Photo
Hi Everyone,
I had an issue yesterday with my K-r. My DA 55-300 was mounted, no flash.
I turned on the K-r and was in aperture priority mode. I quickly clicked 4 or 5 pictures of my son holding a baby alligator (we were at the Florida Jungle Gardens), checked the back of the screen after the last shot...it looked good. I switched the K-r off. About a minute later I turned it on again to look at the photos and they were nowhere to be found.... I took another photo and it recorded this one.
Any idea why my K-r didn't record the photos to the card?
AB
04-11-2012, 07:05 PM   #2
QuoteOriginally posted by ablundon Quote
Hi Everyone,
AB
Does your Kr have the latest firmware update?
The Kr recorded the photo you saw it on the view screen. If the photo's aren't on the card then the card may be the problem. Have you ever formatted the card? Is it a brand name card or a cheap one? Do you have another card you can use for awhile to determine the problem?
04-11-2012, 07:46 PM   #3
QuoteOriginally posted by geru2000 Quote
I think I'm still at version 1.11.... I never bothered with the latest... I need to do that.
I formatted the card two days ago.
The card is Photo Dimensions Class 6 card. I have 2 and never had an issue with either. This card has worked perfectly since the incident. Photo Dimensions is a Canadian based group of 1200 merchants aimed to help the brick and mortar stores compete against large corps. Welcome to Photodimensions! The card was purchased from a local brick and mortar store (per their recommendation).
Good point though...it could be a card error. I'll watch out for that.
AB
04-11-2012, 08:56 PM   #4
twitch's Avatar
Likely it's a card error. I'd reformat it or replace it.
04-12-2012, 09:50 AM   #5
Na Horuk's Avatar
There is some software out there that can help you recover lost data from SD cards, you might want to try it. It probably won't work if you reformatted or saved new data to the card. Btw, the card isn't in the "locked" position, right?
04-12-2012, 06:40 PM   #6
Card is not locked. When I noticed it didn't work I turned off the camera, popped open the card door to check the card was there and then I restarted the camera. Everything was fine after that.
camera, k-r, kr, pentax k-r, photo, photos, record
Failed FW update. Ex Finn. Pentax DSLR Discussion 29 05-23-2012 03:17 PM
Record $4.3m auction price for photo by Gursky sandpipe Photographic Industry and Professionals 13 02-24-2012 09:11 PM
Should students who try hard still be failed? mikemike General Talk 61 11-10-2010 05:14 PM
Photo's Grab Record Prices Fl_Gulfer General Talk 1 06-24-2010 01:08 PM
Broken Record, part II : return of the record Gooshin Post Your Photos! 5 09-14-2008 03:21 PM
All times are GMT -7. The time now is 07:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
