Originally posted by New Englander 12mp, 3 star.
Have tried some RAW shots, then taken a jpeg immediately afterwards with no discernible differences.
With the exception of the Mushroom shot I see nothing that jumps out indicating a lens or even a camera focus problem and
without the Exif data the mushroom shot can't be diagnosed.
What I see is an inexperienced photographer going through the growing pains of photography. We all do it,
I certainly did. I could take 200 photos and after culling the out of focus, horribly exposed, missed framing, on & on,
I'd literally end up with maybe 20 or 30 so-so shots and one or five good ones.
I've thrown away whole folders of bad shots in the beginning.
If you're shooting in P mode I'd suggest shooting in either Tv or Av depending on whether depth of field is important.
Try keeping your Aperture between F5.6 and F8 these are the sweet spots for most lenses and try to keep shutter
speed @ no less than 100 to avoid shake. There are times when these numbers become impractical such as in bright
sun or in poorly lighted buildings. One other suggestion is to turn off auto ISO use this function in areas that aren't well lit
and set the maximum to an ISO that produces an acceptable (for you) level of noise and keeps your shutter speed above 60
at 60 and below the camera needs to be on a tripod. most people can't hold the camera steady enough to avoid shake blur.
Above all shoot tons of photos even if it's photographing nothing more than a pair of sneakers. The more photos you take the
better you'll get. When I first started shooting I'd watch TV and shoot sneakers at the same time
, really.
