04-18-2012, 03:12 PM   #1
Na Horuk's Avatar
Onboard Flash
Hey all. I have a K-r and am very happy with it. I used the onboard flash only once or twice, months ago, and recently I wanted to use it again, but it didn't work. When I pop-up the onboard flash and press the trigger button it won't flash and it won't even take a shot. I tried setting the flash to manual and auto, but neither mode made it fire. Are there some conditions that need to be met for the flash to fire? Does it just need a lot of time and a full battery to charge up? I don't know why it would stop working, the camera didn't sustain any bumps or anything. Some months ago I used a hotshoe mounted flash, could that have "fried" it or something?
04-18-2012, 04:09 PM   #2
parsons's Avatar
my flash is broken too. I'm not sure how i did it.
i hate direct flash, and i only ever used it to trigger my metz remotely - now i have cactus V5s instead, so no harm done
don't know how to help but i would like to know other peoples responses
04-18-2012, 05:27 PM   #3
Philoslothical's Avatar
I've heard of a couple failing, so it reasonably could be an issue requiring service. First thing I'd check is that it's raising properly, and that there's no debris in the hinge. Mine is really sensitive, if I'm wearing a hat or a hood and it so much as touches the raised flash, it doesn't fire. It has to be raised all the way or it's a no-go. Mine does take the shot anyway, so that may not be your issue. Do you have it set to shoot even when charging?
04-18-2012, 05:45 PM   #4
Ash
Community Manager
Ash's Avatar
Also, do you have your camera on a mode that does not fire the flash? Check this in your flash menu setting (down button on your 4 way controller). Or just reset all your settings and try again.
04-19-2012, 02:50 AM   #5
Na Horuk's Avatar
Thanks for the replies!
Yes, the flash menu is set to manual discharge in M mode and I also tried it in darkness in auto mode and it popped up on its own, but didnt fire. It pops up all the way.
I now set the camera such that it fires while charging. Now the camera takes the shot, but the flash still wont fire. How long does ti take to charge? A couple seconds or minutes? Unfortunately the camera is out of warranty and Im not sure I would spend money on fixing this.. it is rather inconvenient, though. Any other ideas?
04-19-2012, 04:02 AM   #6
sterretje's Avatar
Couple of seconds, maybe around 10; never measured it but definitely less than 0.5 minute.
04-19-2012, 09:44 AM   #7
I had the same problem when I used to own a K-r. It was documented in the thread here: Flash won't fire
I ended up mailing it to Pentax Repair in Arizona (CRIS) and they said it was a faulty mainboard or something to that extent. It took them about 2 weeks to get the part and repair the camera. If you're still under warranty, I'd suggest sending it in.
04-19-2012, 12:28 PM   #8
Na Horuk's Avatar
QuoteOriginally posted by einstrigger Quote
Thanks for the link. Did they say this could cause other problems as well? Because it is out of warranty and i can make-do without flash..
04-19-2012, 01:15 PM   #9
It shouldn't cause any other problems, as long as the hotshoe is still functional so you can use an external flash.
04-19-2012, 02:08 PM   #10
Nope, they didn't mention anything else. I pulled up the work order and this was what they listed:
Repair Performed:
WARRANTY
REPLACED FLASH PCB
ADJUSTED TO MANUFACTURERS SPECIFICATIONS
GENERAL CHECK AND CLEAN
Before sending it in, I found that my hotshoe was still working, so I could use an external flash or wireless trigger. Anyhow, I'm glad I got it fixed under warranty as I think this would otherwise be a costly repair. I wouldn't be surprised if this issue is/was occurring with other K-r owners. The camera was definitely a black-eye on Pentax in terms of quality control. I'm glad to be rid of it.
04-19-2012, 02:27 PM   #11
Na Horuk's Avatar
Thanks very much, everybody! I'll see what I can do about this.. probably I'll just not use the onboard flash lol
04-19-2012, 03:32 PM   #12
GabrielFFontes's Avatar
My flash also broke. I'm from Brazil, and then i can't do anything...there is no warranty here.
I bought an AF280T instead. It came defective too, but not completely. The seller quickly refunded me and thats about it...
camera, fire, flash, k-r, kr, months, onboard, pentax k-r
Is the onboard flash WR? Cambo Pentax K-5 9 12-22-2010 01:10 PM
Nature Just playing around with my onboard flash photolady95 Post Your Photos! 2 08-02-2010 05:01 PM
Making some use of onboard flash pentagor Flashes, Lighting, and Studio 10 02-27-2008 01:24 AM
Pentax K10D and Onboard Flash matix Pentax DSLR Discussion 12 03-05-2007 07:53 PM
Using onboard flash with K-Series lens Alvin Pentax DSLR Discussion 7 02-09-2007 05:51 AM
All times are GMT -7. The time now is 12:24 PM. | See also: NikonForums.com, part of our network of photo forums!
