04-26-2012, 11:12 PM   #1
Problem with Zeiss 85mm manual focus lens
I had this Zeiss Planar 85 1.4 few days ago. Very well built lens. It's my first lens without AF.
At the very beginning, I use "focus tip" and "trap focus" of my kr to shoot around. But I found it is not easy to make my photo sharp and clear. So I did a test with focus testing card, I found the focus is running forward from F1.4~F4, when I keep reducing the aperture, the focus runs backward from F4.5~F16. It sees when the aperture is at F4, the focus can correctly fall on the right point.
Under this condition, I will not able to use "focus tip" and "trap focus", but judging focus by naked eye? or use Lv mode will make it easier?
Will it be the problem of the lens? because I never had this problem with my other lens.
04-26-2012, 11:24 PM   #2
Focus confirmation is approximate, so there will be some leeway based on the direction you're turning the focusing ring. The best thing to do with manual focus lenses is to get a split-screen focusing screen so you can accurately focus through the VF.
04-26-2012, 11:52 PM   #3
hcc
hcc's Avatar
I have a CZ85mm f1.4 and I use it with my K-7. I found that the CZ85 focus ring is very, very precise and I tend to trust my own eyes rather than the camera focus confirmation. I have done some limited tests of shots, all with focus confirmation. Some are really nicely focused, others not. I think that the lens is very sharp and need to carefully focused, while the CZ85 focus ring is more accurate than the camera focus confirmation.
A split screen is definitely an excellent idea IMHO.
I do not have a split screen and I rely instead upon taking a burst while gently adjusting the ring. Often I found myself taking 2-3 shots in burst while I gently fine tune the focus ring. I tend to have at least 1-2 good shot(s) per burst.
Hope that the comment may help.:evil:
04-27-2012, 02:14 AM   #4
Thanks for the tip. If I install a split-screen on K-r, will it affect anything if I change my other AF lens on? Or does it have any side effect on camara?
04-27-2012, 02:20 AM   #5
QuoteOriginally posted by hcc Quote
thank you for the suggestion, I think the "burst" try is quite reasonable, I am gonna do this and see how it goes.
04-27-2012, 02:54 AM   #6
Anvh's Avatar
QuoteOriginally posted by frankfanrui Quote
The light meter is now inside the viewfinder housing so the split-screen has some effect on the lightmeter but not so much from what i hear though.
This effect any lens btw.
For the rest no negative side effects to the camera.
04-27-2012, 05:51 AM   #7
kcobain1992's Avatar
Your possibilities are the following, sorted from the cheapest to the most expensive:
-free: instead of using the red light in the center of the viewfinder and the beep, better deactivate them so they don't get in your way, and watch the green hexagon at the bottom, which is the actual focus confirmation (and works well)
-free as well: live view
-$79 plus shipping from Taiwan, an "S-type" matte focusing screen [very precise, much more than the standard screen, reportedly no effect upon metering, including spot
-same price, a microprism or split image screen, if you prefer these
-$105, a split screen from Katz-Eye, add $50 for "OptiBrite" if you think you need it. As far as I know, the screen used is the same as K3 from focusingscreen.com
-$(I don't know how much), sell your lens and get an AF alternative.
04-27-2012, 06:01 AM   #8
Anvh's Avatar
Focusing Screen
most seem to prefer the Ec-B
04-27-2012, 06:23 AM   #9
QuoteOriginally posted by Anvh Quote
Thanks for the information, I think effect on lightmeter is ok for me since exposure time can be easily adjusted.
04-27-2012, 06:25 AM   #10
QuoteOriginally posted by kcobain1992 Quote
Wow, that's a lot of options, I think I will take all of them into consideration expect the last one, I just had it, and I need time to understand it. Thank you by the way.
04-27-2012, 06:28 AM   #11
That's OK, I wasn't really suggesting you to sell it, God forbid. I, for myself, have no AF lens except the 18-55 which came with my K-x, and which I keep only because it is red.
aperture, camera, focus, k-r, kr, lens, pentax k-r, zeiss, zeiss 85mm
Has anyone tried Zeiss 85mm f1.4 ZK mount lens? yliu Pentax SLR Lens Discussion 23 11-03-2011 02:27 AM
Wanted - Acquired: 85mm manual focus yusuf Sold Items 4 08-18-2010 07:13 AM
pentax k-7 SR problem with manual focus lens lwsy711 Troubleshooting and Beginner Help 4 07-17-2010 04:02 PM
Problem with manual focus noabsolutes Pentax DSLR Discussion 14 06-18-2010 06:27 AM
All times are GMT -7. The time now is 06:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
