04-29-2012, 08:52 PM   #1
Pentak k-r shutter problem!
Hey guys,
I recently bought a K-r it has less than one month and it has not been working well. This is the problem is has. It doesn't have any falls or hits. It's new!
I don't know what to do with the warranty cause I bought it in the states on Ebay, but I live in Chile
04-29-2012, 09:00 PM   #2
Sounds like the shutter might be broken, or, if you're lucky, it's just a switch inside the camera. US-based warranty repair shops will only ship the camera within the US, so you'd have to get someone to act as the middleman if you want to send it in.
04-30-2012, 05:52 PM   #3
Sounds like we have the same problem. Have you tried charging the battery? Mine behaved normally when the battery is fully charged. When you put the fully charged battery into the camera there should be a click. then the camera will work normally for a while. Finally the mirror starts clicking at the wrong time and if you go to live view the mirror starts clicking repeatedly because it can not lock into the up position required for live view.
See message "Mirror Cycles At Wrong Time"
If someone knows a fix then we'll both be happy.
05-04-2012, 08:43 AM   #4
wax
Again.
Itīs a over documented issue produced by the voltage of the original battery. Try AAs with a generic or original adapter and will work better than before.
05-05-2012, 04:39 PM   #5
I have this too, it just started tonight. I bought my Kr about two months ago. Do you think this is something to do with a certain batch of cameras? Are you sending it back to where you bought it from?
05-07-2012, 06:44 AM   #6
wax
now my first battery setup are 8 2700ni/mh rechargables AAs batteries with generic adpater. With the 18-55mm kit lens, the magnific DAL 2.4/35 and my ATL(all terrain lens) Sigma 18-200mm, I use the original lithium one.I post this pic becaouse when I modified it mount from contax to Pentax (vivitar K) the mirror slap like no one before. Then I realise itīs a problem related with the original batterie , metering(auto) and flange distance between the lens and the sensor. For example on this case the planar canīt focus to infinty. Since I use AAs on the K-r problem is solved. Despite the issue for me itīs an advantage of the camera the possibility to use AAs.
07-24-2012, 04:07 PM   #7
shutter problem
I had the same problem with my new K-r. You must clean the contacts on the lens and camera. There is a youtube video on how to clean your lens contacts. Cured my problem.
07-26-2012, 12:39 PM   #8
Yes, that solved my problems as well. I think I said this in other threads, but I will repeat it here. Having more voltage from different batteries improved the problem, but cleaning the lens contacts fixed it completely.
QuoteOriginally posted by ranbunctious Quote
07-28-2012, 12:17 PM   #9
Hi i did have same problem with mine than it stopt and it was ok for a few months, but then it comes: after pressing any button or turning with roller it start doing it again and didnt stopt. I have take it back to shop and they replace the whole mechanism in camera. Just want to say that it may resolve your problem for a while but i still think you should take it to shop and get it checked.
camera, k-r, kr, pentax k-r
Pentak k-7 film issue hughcore Troubleshooting and Beginner Help 4 12-01-2011 12:19 AM
K-5 shutter problem blackcloudbrew Pentax K-5 15 08-17-2011 06:02 PM
SV shutter problem on T ebayaholic Pentax Film SLR Discussion 3 01-23-2011 01:43 PM
ist DL Shutter problem? I need help!! airedog Pentax DSLR Discussion 10 09-09-2010 08:17 AM
All times are GMT -7. The time now is 11:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
