05-10-2012, 11:03 AM   #1
lammie200's Avatar
K-r shims
Has anyone received focusing screen shims from Pentax for their K-r? I replaced my screen a few months back. At the time it seemed to focus fine without any shims. Now it seems like it needs a tad of shimming. I called Pentax parts and they are sending me a shim kit, but I am a little suspicious because she said that most K dSLR's take the same shims. I don't think that that is true, but I guess I will find out more once I receive them. Just wondering if anyone has used the Pentax metal shims for their K-r.
05-10-2012, 11:13 AM   #2
JimJohnson's Avatar
When you refer to focusing problems, are you talking about manual focus or auto-focus? If it is your auto-focus that is off, you should make your adjustments via the menu. If it is manual focus with the stock screen that is off, this is a first I've heard of this kind of problem.
Here is a link to my previous discussion on adjusting the auto-focus for your K-r.
05-10-2012, 11:34 AM   #3
lammie200's Avatar
QuoteOriginally posted by JimJohnson Quote
I replaced the screen with one from focussingscreens.com, so I am no longer using the stock screen. I don't want to use the floppy shims that came with the kit. I am just wondering if anyone has purchased the metal shims from Pentax for their K-r. I was told that they should be the same as the ones for other K cameras. I am just a little skeptical of that.
05-10-2012, 02:30 PM   #4
kcobain1992's Avatar
QuoteOriginally posted by lammie200 Quote
Why not?
05-10-2012, 03:34 PM   #5
Jonathan Mac's Avatar
I think there are two different sizes of shims. The ones for the lower end cameras (K200D, K-x, K-r etc) are different from those for the higher end cameras (K20D, K7, K5 etc).
I recently re-shimmed my K200D to improve manual focus with my Katzeye screen and now it's spot-on.
05-10-2012, 03:39 PM   #6
lammie200's Avatar
QuoteOriginally posted by kcobain1992 Quote
Why not?
I might try and use one, but stacking them is hella difficult. I did have one in there before. I might have been too quick to remove it, or maybe I need one that is even thinner. Last resort will be scotch tape, but I really want to go plug and play on this if you get my drift.
05-13-2012, 04:31 PM   #7
hnikesch's Avatar
I had to add a shim when I replaced the screen on my Km with a split image, I like the stock screen on my Kr
Hans
05-14-2012, 12:56 PM   #8
I stacked three of them in my K-x. Stack them by hand, then use the pliers supplied to put them in place. It will work, eventually.
camera, k-r, kr, pentax, pentax k-r, screen, shims
Katzeye on order do I need shims? (K20D) PPPPPP42 Troubleshooting and Beginner Help 4 02-07-2012 09:59 PM
focusing screen and shims K5. Need help adjusting. mrjamesabels Troubleshooting and Beginner Help 8 07-26-2011 07:25 AM
K7 Screen Shims Wheatfield Pentax DSLR Discussion 15 09-10-2010 06:47 PM
K-x focus screen shims distudio Pentax DSLR Discussion 4 09-10-2010 02:53 PM
Shims for Focus Screen in K10D? smigol Pentax DSLR Discussion 22 05-14-2009 01:26 PM
All times are GMT -7. The time now is 10:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
