05-15-2012, 11:06 PM   #1
Camera would not revive after long shutter exposure
So i pointed my camera at the stars with the shutter setting on bulb. I probably left it open for 30min or so.
I started and finished the exposure with a remote with no issues. But the camera went dark and never revived. i turned it off and then on again, and nothing. Thinking the battery may have died i ejected it and stuck it back in to se if i get any signs of life. After that the camera turned on and everything is fine but the picture i took is not there...
Any advice for me?
05-15-2012, 11:13 PM   #2
Disable slow shutter speed noise reduction and you should be good to go.
05-15-2012, 11:30 PM   #3
sterretje's Avatar
There is something called dark frame subtraction (DFS). After a long exposure, the camera will take an equally long second photo with closed shutter (in your case 30 minutes) to subtract from the first one eliminating some noise. So either wait patiently or follow Adam's advise.
From hearsay (not tried myself):
If you're doing multiple long exposures, it's less time consuming to switch it off and take one photo with the lens cap on and subtract that later in post processing.
05-17-2012, 06:33 PM   #4
Your camera was still "processing" the photo you took. By removing the battery you prevented the processing from completing, so the image was never saved.
As above you can either disable Slow Shutter speed Noise Reduction, or wait!
05-17-2012, 07:09 PM   #5
joe.penn's Avatar
Even with "sspnr" disabled, DFS will still run (I believe) if the exposure is 30 seconds or longer - sit back and have a beer while waiting
camera, exposure, k-r, kr, pentax k-r, shutter
Long exposure / provia 200 : how to know the good exposure compensation ? aurele Pentax Film SLR Discussion 3 02-18-2012 06:58 PM
Long exposure shots (camera) kaiserz Pentax DSLR Discussion 15 01-05-2012 10:12 AM
Long Exposure Help scorpionbowl Pentax DSLR Discussion 4 07-29-2010 04:48 PM
How long will fresh batteries last in long exposure? tnis0612 Troubleshooting and Beginner Help 6 05-18-2010 09:11 AM
Long exposure camera noise Alex00 Pentax DSLR Discussion 2 02-27-2010 05:55 AM
All times are GMT -7. The time now is 02:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
