06-05-2012, 12:30 PM   #1
Flash Question
I was just swapping out camera bags and I found my old Minolta Auto 200x Flash that I used on one of my old 35mm cameras.
I'm just wondering, before I try it out, if this flash is compatible with my new K-r, and if it could damage it if I try it out.
Thanks in advance.
06-05-2012, 12:33 PM   #2
Pablom's Avatar
You could definitely fry you're camera to a non working state. DON'T TRY IT OUT!!!
06-05-2012, 02:46 PM   #3
philbaum's Avatar
If you'Ve got a multi-meter with DC scale, you can see what the maximum voltage is on the base contacts after the flash has been powered up. Pentax has never said what the maximum DC voltage their digital cameras will take, but the consensus on this board from various discussions seems to be 12 volts. Canon limits the voltage to their digital cameras to 4 volts or something like that. Some older flashes have been measured up to 70 volts on their contacts. There is a website by one of the PF members that discusses this parameter. don't have the link to the website at the moment but shouldn't be hard to find.
06-05-2012, 06:25 PM   #4
Philoslothical's Avatar
This is the link. The Minolta Auto 200x should be OK, according to that page.
06-06-2012, 03:49 AM   #5
QuoteOriginally posted by Pablom Quote
Thanks for info.
06-06-2012, 03:52 AM   #6
QuoteOriginally posted by philbaum Quote
If you'Ve got a multi-meter with DC scale, you can see what the maximum voltage is on the base contacts after the flash has been powered up. Pentax has never said what the maximum DC voltage their digital cameras will take, but they're consensus on this board from various discussions seems to be 12 volts. Canon limits the voltage to their digital cameras to 4 volts or something like that. Some older flashes have been measured up to 70 volts on their contacts. There is a website by one of the PF members that discusses this parameter. don't have the link to the website at the moment but shouldn't be hard to find.
Sounds like it's not worth taking a chance on ruining a new camera over.
I think I'll just put it back with the 35mm and get one specifically for my K-r.
Thanks
06-06-2012, 03:55 AM   #7
QuoteOriginally posted by Philoslothical Quote
I don't think it's worth the risk.
Thanks very much for the information.
06-06-2012, 04:53 AM   #8
HockeyDad's Avatar
QuoteOriginally posted by TheBear Quote
IMHO, it is definately not worth the risk of just blindly sticking it on there and testing it. However, the only flash I own and use with my K-r is an old Minolta 132x. As others have posted, it boils down to trigger voltage. I did use a DC volt meter to ensure it was under 7v (At the time I read conflicting warnings from so I went with the lowest.) Turns out, it was less than 2v... so really no issue for me.
Meter it and see.
camera, flash, k-r, kr, pentax k-r
flash question ap_exclamationpoint Pentax K-5 9 04-07-2012 05:29 PM
K-x flash question mikknu Troubleshooting and Beginner Help 4 08-16-2011 03:39 AM
Flash question elsdad Pentax Medium Format 3 06-05-2011 03:54 PM
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
Flash Question - Turning Off Flash Quickly For a Shot sweetpapa Pentax DSLR Discussion 5 06-16-2008 12:04 AM
All times are GMT -7. The time now is 02:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
