Hi all.
I just ordered one of these remotes to use with my Pentax K-r
JOOX - Compatible IR Remote control Shutter Release for: Amazon.co.uk: Electronics
It arrived today, I removed the plastic strip which seals the battery, and gave it a go. Nothing.
So the puzzle is, is the problem the remote or the camera (or a setting therein)? I can't seem to see a setting to simply turn IR on/off, but wonder if anyone with more knowledge could advise. Reviews suggest it should 'just work'.
I also tried my TV remote, aiming it at the camera in an attempt to make something happen and prove it was the remote, not the camera. Alas, nothing happened.
Any thoughts would be appreciated
