09-08-2012, 01:47 PM   #16
Thank you all for your helpful and really prompt responses.
09-08-2012, 01:52 PM   #17
QuoteOriginally posted by mattt Quote
In this case, I dissagree. The error was not the camera's. As I mentioned above, the EXIF clearly states a manual white balance was selected.
Fair enough, but it is still a common problem with manual lenses with AWB on.
09-08-2012, 02:12 PM   #18
Is the point you are referring to (which I know doesn't explain my photos) a common problem with the more modern K-30 and K-5 as well?
09-08-2012, 03:19 PM   #19
QuoteOriginally posted by mephistophelean Quote
It is more of a fault of the lens itself than the camera, many old lenses have a natural color cast to them. I have a homemade Expodisc clone made from a couple cheap UV filters and a coffee filter to set white balance, this totally solves the problem. I always try to remember to reset the white balance when changing lenses, but sometimes I forget, which is why I shoot RAW.
Even in the worst case though, it shouldn't be as extreme as your first post shows, that was clearly operator error.
09-08-2012, 03:21 PM   #20
JohnBee's Avatar
It is the white balance, and nothing to do with yellowed glass or anything like that. It happens all the time with manual lenses under artificial light -- I think it is because only spot metering is enabled with manual lenses and it just isn't good at setting WB depending on what you are pointed at.
People still use AWB?
09-08-2012, 03:50 PM   #21
QuoteOriginally posted by JohnBee Quote
Never anything else -- I shoot RAW, doesn't matter if I mess it up.
09-08-2012, 03:54 PM   #22
hnikesch's Avatar
If your new to Pentax dslr's you must enable the aperture dial and use the green button to meter manual type k mount M lenses. I am on my phone or I would attach a link, do a search for the procedure. I use manual lenses on my KR often they work great.
Hans
09-09-2012, 04:49 PM   #23
Here is a couple of links , to help you set up your camera
Using Older Lenses with the PENTAX K-x | Pentax Support
This thread will help you too
https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-meter...k-x-k-7-a.html
09-09-2012, 06:34 PM   #24
SpecialK's Avatar
Yep. I rarely have an issue.
50mm, body, camera, f1.4, idea, iso, k-r, kr, lens, pentax k-r, photos
Linear Polarizer in Manual with manual lens Den Photographic Technique 8 12-19-2012 11:10 PM
loved the idea of reverse-lens macro, BUT... slr_neophyte Troubleshooting and Beginner Help 18 08-31-2011 08:05 AM
3 lens kit idea - reflections? Thrasis Pentax SLR Lens Discussion 17 01-29-2011 08:11 AM
Lens Correction: Good or Bad Idea? bigdave56 Pentax DSLR Discussion 20 10-31-2010 03:58 PM
Do oversaturation and warmer color balance sound like sickness? Adnan EROL Photo Critique 7 11-12-2007 06:19 PM
All times are GMT -7. The time now is 06:32 PM. | See also: NikonForums.com, part of our network of photo forums!
