09-24-2012, 08:00 PM   #1
Insane ISO Dilemma (K-r)
So I was wondering if anyone has had a similar problem, and if they have fixed it, or if anyone knows a possible solution on how to fix my dilemma.
So here is my story: I have expanded my K-rs ISO sensitivity to 100-25600, and I was taking a lot of pictures at a night luau where I needed to switch between 800 and 1600 ISO. The next morning when I went to change ISO settings back to 100 for landscape photography, the lowest setting that I could get down to was 200. So I went ahead and changed my setting back to normal (unexpanded) setting to see if I went through the expanding cycle, that the camera would reset ISO expandability; it in fact did not and the lowest setting on expanded sensitivity is still 200 ISO. The really weird part is that when I switch to normal (unexpanded) ISO setting, is that the lowest setting should be 200 ISO, but now says it is 400 ISO. In essence, the lowest setting doubled itself. WTF I was screaming to myself. So I am here, pleading to anyone who has experienced something similar, hoping that there is a possible solution.
Any help is greatly appreciated!
Thank you much!
09-24-2012, 08:11 PM   #2
What setting is your camera in? If you have shadow compensation enabled, the lowest it will let you set the iso to 200. I think the night scene mode might have shadow compensation enabled by default.
09-24-2012, 08:27 PM   #3
Thank you so darned much! It was the Highlight Correction setting that was turned on; I must have accidentally switched that on with the E-dial going through menus. I had no idea that it did that. Again, thank you, thank you, thank you!!!
09-24-2012, 08:48 PM   #4
You're welcome, I remember having that issue on my K-x a while back, and for some reason it never left me. ^^ Have fun with your K-r! Happy shooting!
09-25-2012, 10:07 AM   #5
skism's Avatar
I had the exact same issue with my K-X too, and it took me a while to figure it out. It was the darndest thing until I understood what happened.
camera, dilemma, iso, k-r, kr, pentax k-r, sensitivity, solution, switch
What caused an entire nation to go insane jeffkrol General Talk 89 05-19-2012 07:10 PM
Parking your car drives you insane (and it costs) RioRico General Talk 8 01-11-2012 10:38 PM
K5 vs 5D Mark II - Wow, the K5 is insane! crossover37 Pentax K-5 88 04-29-2011 10:54 PM
Did I go insane or is this reasonable? Chaos_Realm Troubleshooting and Beginner Help 21 04-20-2011 12:54 PM
my antenna ball is insane bimjo Pentax SLR Lens Discussion 6 11-22-2010 12:51 PM
All times are GMT -7. The time now is 04:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
