10-06-2012, 07:17 PM   #1
Reflection from the window
Hi,
I have just purchased a Pentax K-r and I would like to know how to avoid reflection when I take a picture through a window ?
Thank you,
Masaryk
10-06-2012, 07:43 PM   #2
Welcome to the Forum!!! Use a polarizer. You will need a circular polarizing filter, that screws on to the front of your lens. They come in different sizes. Check the lens for the filter size that it will take. What lens do you have? I am guessing the kit lens? If so here is the lens information....... and takes a 52mm filter.
10-06-2012, 08:57 PM   #3
JinDesu's Avatar
Polarizer will help.
If it can also be helped - more light from the other side of the window will reduce reflections on your side.
10-06-2012, 08:59 PM   #4
johnyates's Avatar
Buy a cheap collapsable rubber lens hood. Position your lens cushioned against the window by the hood.
10-07-2012, 03:33 AM   #5
JimJohnson's Avatar
All good advice above this.
Position a large black cloth at an angle to the glass. Position your camera at an opposite but equal angle to the glass.
Avoid using flash. If you must use flash, position the flash at an angle to the glass.
10-07-2012, 05:10 AM   #6
Thank you !
Hello,
Thank you all for your quick response and all the information !
Masaryk
camera, k-r, kr, pentax k-r, reflection, window
flower reflection in the window d-tune Monthly Photo Contests 0 06-03-2012 07:51 AM
Event Outside the window gelokrol Mini-Challenges, Games, and Photo Stories 2 03-19-2011 06:51 PM
Nature What's outside your window? charliezap Post Your Photos! 15 02-02-2011 08:43 AM
Nature Out my Window Rupert Post Your Photos! 2 12-05-2010 01:21 PM
Suggestion change the javascript imgwide window to a simple browser window JesseDavis Site Suggestions and Help 2 03-10-2010 10:25 AM
All times are GMT -7. The time now is 08:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
