12-06-2012, 11:50 PM   #31
QuoteOriginally posted by jlaubza Quote
Hi, sorry to say but those pix are blurred - maybe your shutter speed is too low for your hands?
The shutter speed looks fine, but I do notice the shake reduction is set at 8mm. So it could be working against him.
It does look like you need to put the aperture on the A position to make full use of it on your DSLR, otherwise you're stuck with M mode only. Since you are in Av mode the lens is only staying wide open at f2, so your DOF is shallow and the lens isn't at its sharpest. I found mine to be very good at f4 and above. If the lens is in the A position, then the contacts on the body or lens might be dirty or there might be something wrong with the mount of the lens.
12-08-2012, 05:07 AM   #32
jt1667's Avatar
Thanks for the advice, Ill take a look at it. Keep in mind that those pictures were the first ones Id ever taken with a manual lens. Since the original postings Ive been able to get ahold of two more screw mount lenses (a 55mm & 28mm). My 55mm screw mount im in love with! It takes great photos.
12-11-2012, 03:51 PM   #33
I have a smc Pentax-A 50mm f1.4. Quite easy to focus manually.
12-12-2012, 09:27 AM   #34
I have just bought an A 50mm 1.4 as wanted to get a prime without spending too much, and also wanted to play around with an older manual focus lens. Haven't really explored it much yet but no doubt I will be coming back here for some help once I do...
camera, k-r, kr, lens, pentax k-r
Sigma 17-50mm F2.8 vs Tamron 17-50mm and Pentax DA* 16-50mm Adam Pentax SLR Lens Discussion 89 12-28-2014 07:28 PM
For Sale - Sold: Pentax M 28mm 3.5, Sears 55mm 1.4, Ricoh P 50mm 1.7, Chinon 50mm 1.9 (Worldwid causey Sold Items 17 01-08-2011 11:14 AM
For Sale - Sold: F 24-50mm 4, A 24-50mm 4, M 35mm 2, M 50mm 1.4, A 35-105mm 3.5, A 70-210mm 4 raybird Sold Items 7 08-29-2008 01:06 PM
All times are GMT -7. The time now is 10:15 AM. | See also: NikonForums.com, part of our network of photo forums!
