10-29-2012, 09:53 AM   #1
Flash
Hi guys, im new to all this photography stuff but i know i need a decent flash on the camera other than the built in one, can anyone recomend one to me please???? nothing to pricey
10-29-2012, 10:05 AM   #2
Anvh's Avatar
Metz 50
10-29-2012, 11:07 AM   #3
ChooseAName's Avatar
Yes, that. Unless you're planning on using the flash off-camera a lot, in which case you might want to go with a Yongnuo flash, which is a manual-only flash.
10-29-2012, 10:03 PM   #4
ajaya's Avatar
is there any automatic flash?
10-30-2012, 04:43 AM   #5
QuoteOriginally posted by ajaya Quote
Look here for a list of which Pentax flashes have what features.
10-30-2012, 05:30 AM   #6
If you don't mind going with a used flash, I really like the Sunpak 422D. It's both manual and automatic, and it has variable power, which is very handy.
10-30-2012, 09:16 AM   #7
I've been pretty happy with my Sigma DG-Super Series. Get the highest guide number (power) you can afford.
Photo 4 Less - Professional Photography Equipment, SLR Cameras, Lenses, Flashes
Tim
10-30-2012, 11:04 AM   #8
thanks guys, looks like i have a lot of research to do
10-30-2012, 03:21 PM   #9
Unless you have a K-30 I would strongly recommend the Metz 58 AF-2.
If you do intend to use it with K-30 it has currently some limitations (incompatibility). The most significant limitation is the High Speed Sync, which may or may not be important to you. It also seems to be a bit unreliable (when used with K-30) in the auto exposure, typically severely underexposing some shots.
I also use the same flash with the K-r and it has no such issues.
One very positive point about this flash is that the firmware is easily upgradeable by USB, just as you would upgrade the camera firmware. This means that such limitations and incompatibilities that crop up when new cameras are launched can be sorted out without having to send the flash to a service centre. This means that the limitations I mention are likely to be solved quite soon. I have contacted Metz and they confirm that they know about the issue and it is on their to-do list, even if they could not give me a specific date when they would issue the firmware update.
edit: I just realised that this is the K-r thread so I assume you will be using the flash with a K-r. So the problems I mention do not apply.
Last edited by lister6520; 10-30-2012 at 03:24 PM. Reason: Didn't realise this was the K-r thread
10-30-2012, 05:33 PM   #10
hnikesch's Avatar
I use 2 old auto 1980's vintage flashes a Pentax AF200T and a Sunpack Auto 30DZ, just set shutter speed to 180 and aperture to chart on flash and it works on auto flash mode for the range stated on the flash. You should be able to get a good flash on Craigslist for less than $50 What ever flash you chose watch the trigger voltage, see link for chart Photo Strobe Trigger Voltages
Hans
10-31-2012, 07:16 AM   #11
this might sound a bit stupid buts whats the difference between a manual and an automatic flash????? im just shooting landscapes and macro stuff no studio work
10-31-2012, 07:34 AM   #12
JimJohnson's Avatar
QuoteOriginally posted by TheCornishGiant Quote
Upfront, flash and landscape photography rarely cross paths unless you are adding light to a closer subject in front of a landscape. I'll suggest that light reflectors are a lot less expensive and can often do a better job in this situation. There are nice folding cloth type reflectors, but even a sheet of white posterboard can work quite well.
A manual flash puts out a certain percentage of its capabilities based on the photographer's input. Old flashes tend to offer only one setting - 100%. And be VERY careful using many old flashes on current camera bodies. Current camera bodies have much lower voltage tolerances and old flashes tend to pump high voltages through the camera.
In broad terms, there are two types of automatic flashes. One type uses the camera's metering system to stop the flash output when the subject has enough light and the other uses a sensor built into the flash to make this same determination.
The in-camera type of automation varies both between brands of cameras and models of cameras. In the Pentax world there is both TTL and the newer P-TTL systems. The K-r can only use P-TTL and doesn't support the older TTL system.
The in-flash type of automation typically uses something called a 'thyristor'. On Pentax's flashes supporting this type of automation there is usually a 'T' in the model name.
Again, old flashes and new cameras are often not a good mix.
10-31-2012, 09:19 AM   #13
thanks Jim thats awsome.
10-31-2012, 05:16 PM   #14
Anvh's Avatar
Ring flash is very nice for Macro.
10-31-2012, 05:43 PM   #15
jeffshaddix's Avatar
QuoteOriginally posted by ChooseAName Quote
Yes, that (Metz 50). Unless you're planning on using the flash off-camera a lot, in which case you might want to go with a Yongnuo flash, which is a manual-only flash.
Why is the Metz 50 not good off-camera? It has wireless P-TTL AFAIK.
camera, flash, k-r, kr, pentax k-r
Flash for macro photography catastrophe Flashes, Lighting, and Studio 31 10-13-2013 04:41 PM
K10D and flash syncing jeztastic Troubleshooting and Beginner Help 3 11-22-2011 04:18 PM
How do you know how much flash to get? justtakingpics Flashes, Lighting, and Studio 29 04-06-2011 07:59 AM
Best Flash For Macro? on Pentax Kx SFEAR Flashes, Lighting, and Studio 2 03-26-2011 05:56 AM
FW 1.03 - flash modes bxf Pentax K-5 6 03-11-2011 08:15 AM
All times are GMT -7. The time now is 09:08 PM. | See also: NikonForums.com, part of our network of photo forums!
