03-18-2013, 04:52 AM   #1
filters
I have a k-r pentax with lens 55mm-80mm. My husband bought me a Hoya 55mm pro digital filter but it doesn't fit. The inside of the lens says 52mm. Is this the actual size I need? And what brand is recommended?
Thanks
Erica
03-18-2013, 05:02 AM   #2
CB Knipp's Avatar
Yes, 52mm is the size you need. Do not worry though. I would just go online and pick up a cheap 52mm-to-55mm step-up ring. This will thread onto your 52mm lens and then you can screw the 55mm filter onto it. You should be able to get one for a couple bucks. If you are talking about what brand of filter is recommended, then Hoya is a good one (especially the pro stuff). B+W and Heliopan are also excellent.
03-18-2013, 09:57 AM   #3
QuoteOriginally posted by CB Knipp Quote
yeah, but she would have to buy a 55mm front cap too, for a tele zoom which doesn't need a larger filter, if possible just return and get a 52mm, end of story
03-18-2013, 12:53 PM   #4
JimJohnson's Avatar
QuoteOriginally posted by tcbubbleleo Quote
Not to mention possible problems mounting a hood.
03-18-2013, 03:03 PM   #5
VisualDarkness's Avatar
Do you even need the filter?
03-18-2013, 03:41 PM   #6
QuoteOriginally posted by VisualDarkness Quote
IMO, No. I use them with the glass removed because I prefer the old style 51mm push on caps on the 21, 40, 50 (1.4 A) and 28.
03-27-2013, 05:24 AM   #7
I use a clear filter as a lens protector. I get into some situations where i'm having to climb or other things and have banged the lens breaking the filter instead of the lens. If you are never going to be accidently banging your camera you don't need the filter. I use clored filters in my work to photograph certain processes or light sources ( IR, UV, Blue,Green, & chemicals) I have 5 different color filters for use and I buy the right size for each lens ,52 for my 18-55 & 55 for my macro. Hoya is a good brand.
camera, k-r, kr, lens, pentax k-r
What your photo filters say about you boriscleto Photographic Industry and Professionals 4 12-12-2012 06:33 PM
Filters, Filters and more Filters SMcGuire45 Pentax SLR Lens Discussion 15 08-21-2012 12:46 PM
Graduated ND filters...what type do you use? slackercruster Pentax SLR Lens Discussion 8 05-27-2012 07:43 PM
Square filters for Sigma 8-16mm : Dimensions of Lee, Hitech, Tiffen filters? beholder3 Pentax Camera and Field Accessories 3 05-20-2012 05:37 PM
Good Times with Bad Filters interested_observer Pentax Camera and Field Accessories 5 06-25-2011 08:24 PM
All times are GMT -7. The time now is 06:57 AM. | See also: NikonForums.com, part of our network of photo forums!
