03-24-2013, 09:25 AM - 1 Like   #1
Odd rubber flap
This morning I grabbed my K-r because I read about something on the forums and wanted to play with my camera. However, I could not remember what it was that I wanted to try, so instead I just fondled and admired the beauty that this camera is.
When I turned the camera over, I discovered there is a little rubber flap on the corner of the battery compartment door. After 2.5 years I thought I knew every nook and cranny of my camera. My initial thoughts where: "What the heck is this for?" Since I thought the optional AC charger went in the side (with the video out). Turns out, I was wrong and after a little bit of internet searching, I found out it is for the AC adapter. I did not know they give you a dummy battery that you plug into. Pretty cool
03-24-2013, 09:58 AM   #2
Jean Poitiers's Avatar
OK - I never noticed this before ... Now, I got to go look at it. But the bigger question would be where is the K-r in the house, because it is now my wife's DSLR ... J
03-24-2013, 10:09 AM   #3
monochrome's Avatar
FWIW, they use similar technology for the Q and K-01 AC Adapters.
03-24-2013, 04:31 PM   #4
calculator01... yes, this is for the AC adapter. I have the adapter, and the little flap is a perfect fit for the cord. The power setup for these things seems a little silly (your reference to a port in the side would actually make much more sense), but it works.
03-24-2013, 06:30 PM   #5
JimJohnson's Avatar
https://www.pentaxforums.com/forums/do-yourself/217023-build-ac-adapter-pentax-k-r-k-30-a.html
Open the pdf file and you'll see a photo showing the power cord snaking out from this port.
ac, battery, camera, flap, k-r, kr, pentax k-r, rubber
Replacing the rubber grip RickyFromVegas Pentax K-01 2 01-31-2013 01:49 PM
K-01 rubber door? harleynitelite Pentax K-01 10 11-08-2012 02:37 PM
Rubber EyeCup borish Pentax K-30 & K-50 5 10-25-2012 05:55 AM
K5 Mirror Flop | Flip | Flap - Ummmmmm joe.penn Pentax K-5 6 04-22-2012 09:29 AM
pentax mz10 mirror flap spring replacement. njht2 Troubleshooting and Beginner Help 1 04-03-2011 09:33 AM
All times are GMT -7. The time now is 05:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
