Originally posted by hcc Check is you have any in-camera processing: high-ISO noise reduction, lens distortion correction.....
These options slow down the write-up time.
Turning off lens distortion and late-chromatic-ab adj made it more quicker/what it used to be for write up time. Thank you!
Originally posted by Philoslothical Clean the contacts on both the lens and lens mount. If debris is interfering with the proper connection between lens and body, you can get some pretty strange effects. It's also remotely possible that the lens is damaged.
Contacts as in the gold spherical shaped things? If so, does it matter which methods to use since I see there's a couple. (blower/brush, rubbing alcohol and eraser)
