Thats too bad.
Make sure you don't have bracketing enabled, you don't have hdr (or other scene modes) turned on, and that you don't have exposure compensation, as any of these might cause your images to have +/- exposures.
And yes, its great if you can try another lens.
Then there is the usual method:
-try different battery, charge it up, let it sit outside the camera overnight
-reset to factory defaults in the menu
-clean the lens contacts, camera mount
-update firmware
Beyond that, try looking at the meter closely, is it stable, or does it keep changing even if the scene remains the same? What about in live view, is it better?
