09-04-2013, 01:11 AM   #1
Vivitar 3.5 35-200 P/K A adapter for K-r
I have an old Vivitar 3.5 35 - 200 zoom from my ME Super that I would like to put on my K-r. But it does not fit. What adapter do I get and where to attach this lens to this camera?
Thanks
09-04-2013, 02:42 AM   #2
There is likely a large shield around the aperture lever, this interferes with newer bodies, many Vivitar zooms have this issue. What you need to do is remove the shield and either trim it down to normal size or leave it off entirely. On the ones I have I just left it off, it doesn't seem to affect anything. There should be a few small screws holding it on.
09-04-2013, 02:44 AM   #3
RollsUp's Avatar
I'm going to guess that your Vivitar lens has a extra long flange than the later ones. If I am correct then you will either need to remove the flange or, cut off most of it to use it with your camera.
Vivitar Flange Interferrence Fix
Edit: Never mind, elliot beat me to it.
09-04-2013, 09:26 AM   #4
Wow! That was a quick and helpful response. You guys are absolutely right about the flange. I thought I would need to get an adapter. As your experience has shown that the flange an be removed with no harm, I am digging out my tiny screwdrivers. Thanks a lot!
09-05-2013, 01:57 AM   #5
It Works!
I followed your directions exactly and the darn thing works perfectly, even in auto mode. Nice to have the f-stop set automatically. However I think I will set it to it's best opening, f5.6, and allow the camera to just set shutter speed.
Thanks so much for the advice.
Cheers
03-23-2014, 02:25 PM   #6
QuoteOriginally posted by elliott Quote
Worked great for me! Thanks - I thought I was going to have to sell the lens. I didn't want to because it is so capable with the focal range and f3.0 speed. Removing the ring kept me from doing the unthinkable. The only thing I noticed is that the zoom won't go past about 80mm to get to 35mm once off the camera (for storage in the case) unless you move the aperature lever very slightly. On camera it works fine.
Thanks again!
adapter, camera, k-r, kr, pentax k-r, vivitar
For Sale - Sold: Vivitar 2x Macro Focusing Teleconverter, P/K-A, R-P/K tas 0425 Sold Items 6 07-09-2013 07:30 PM
For Sale - Sold: SMC Pentax-M 50mm F4 Macro, Vivitar P/K-A R-P/K 2X Macro TC RollsUp Sold Items 22 06-07-2013 12:45 AM
New Firmware For K-01, K-30, K-5, K-5 II, K-5 IIs, K-r Adam Pentax News and Rumors 63 02-18-2013 02:04 PM
p/k-r to k mount adapter HELP! huntlg Pentax SLR Lens Discussion 16 07-06-2012 08:38 PM
All times are GMT -7. The time now is 06:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
