11-01-2013, 03:23 PM   #1
Autofocus not working
I was shooting as normal today (product photography, was outside) and out of nowhere by auto focus will not work. It does not work in live view or through the view finder. It does not do anything, no red dots, no beeping, absolutely no focusing. I have had my Pentax k-r for almost 2 years now, I have had no problems out of it. I'm not well-versed in photography whatsoever. Please let me know if there is anything that I can do to fix it.
11-01-2013, 07:57 PM   #2
Have you tried with more than just 1 lens?
11-02-2013, 08:05 AM   #3
JimJohnson's Avatar
In addition to Adam's question....
Silly as it sounds, make sure your switch is in the AF position.
Try unmounting the lens. Make sure the AF screw is extended. Press and release the lens release button - you should see the screw retract and extend. If if is not extended, nudge it gently with the tip of a ballpoint pen to see if it will pop out on its own.
If the screw does extend, put the lens into the camera's lens mount but do not turn it yet. Hold in the lens release button, then turn the lens all the way to its stop (do not force it, just turn all the way to the stop). Release the lens release button and gently turn the lens backward in the mount until the locking pin engages - this will help make sure the screw is aligned with the socket in your lens.
camera, k-r, kr, pentax k-r, photography, view
RE: Autofocus not working on KII 5 Body with 77mm 1.8 Borislav Troubleshooting and Beginner Help 9 07-20-2013 12:14 PM
Pentax 200mm f/2.8 autofocus not working? milka Pentax SLR Lens Discussion 15 02-26-2013 12:46 PM
K-5 + 18-55mm Wr - Autofocus not working?? hknymz Pentax K-5 11 02-29-2012 04:50 AM
Pentax-DA 35mm F2.4 AL autofocus not working mr_white Troubleshooting and Beginner Help 6 01-20-2012 04:01 PM
Grrr...autofocus on k-x not working rachcobb Troubleshooting and Beginner Help 9 01-10-2012 09:29 AM
All times are GMT -7. The time now is 05:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
