02-07-2014, 08:09 PM   #1
Beaugrand's Avatar
Body Armor
I'm looking for body armor for my K-r (and my Canon EOS Rebel T3), or a fitted leather case like I have for my film cameras, but can't seem to find any except for Nikons and other Canon cameras (just not the one I have). Who makes them? Where do I get a complete product list?:
On another topic, I have a PK/A 75-300 zoom lens that fits my 35mm Program Plus but not the K-r. Do none of the PK/A lenses fit?
02-07-2014, 08:53 PM   #2
Take a picture of the bayonet and post it if you can.
02-08-2014, 12:48 AM   #3
Beaugrand's Avatar
Vivitar 75-300mm 1:4.5~5.6 MC PKA bayonet
Took a series of pictures of the Vivitar 75-300mm 1:4.5~5.6 MC PKA lens. It does not fit the K-r body due to mechanical interference.
02-08-2014, 12:53 AM   #4
The piece I have circled is your problem. I have seen this before, the thing to do would be remove the 3-4 screws holding it in and swapping it with another lens, for the most part they are all the same. If you have a junk lens somewhere i would canabalize the part needed. any M or A lens should work.
02-08-2014, 02:23 AM   #5
Beaugrand's Avatar
What is the purpose of that piece? I've got a number of PK lenses, but I don't recall seeing that.
02-08-2014, 04:31 AM   #6
Beaugrand's Avatar
Well, it wasn't as simple as finding a similar lens and swapping the part. 6 different brands, 6 different designs. Some had no visible screws, the first one I looked at had three screws, but the original lens has two. In most, that piece is plastic. On the one I've performed surgery, it's metal. I ended up simply removing material with my Dremel, after measuring and scribing a line to follow. I made sure it functions, next I'll clean it up a bit and color it black where the metal is shiny.
I appreciate the help.
02-08-2014, 03:09 PM   #7
Beaugrand's Avatar
I figured it out before I found the solution: www robertstech com slash flange htm shows that material must be removed. I used my dial calipers to determine what needed to be cut away, scribed a line, then used my needlenose visegrips to nibble away 1/16" at a time; then I used my Dremel to grind away the rest of the material, and smoothed it out with an emery board. I covered the shiny metal using a black marker.
02-08-2014, 07:52 PM   #8
Should work like a champ now, glad you got it whipped. It never ceases to amaze me to see some of the things we do to use legacy glass on our cameras
armor, body, camera, cameras, canon, case, compatibility lens, k-r, kr, pentax k-r, pk/a, skin
For Sale - Sold: Pentax K10D (Body Only) w/ MADE Camera Armor cj8_jeep Sold Items 0 10-01-2012 01:33 PM
Oil on aperture - Armor all? Aka Steve Pentax SLR Lens Discussion 10 06-28-2012 09:51 PM
Body Armor?? rmtagg Pentax Camera and Field Accessories 25 04-05-2008 07:31 AM
All times are GMT -7. The time now is 05:13 AM. | See also: NikonForums.com, part of our network of photo forums!
