03-05-2014, 03:25 PM   #1
jerryleejr's Avatar
Memory card error
Any idea why kr won't read any memory card?
JJ
03-05-2014, 03:28 PM   #2
Try formatting your card in-camera. Also, if you're still running firmware 1.00, you will need to upgrade it to use SDXC cards. I recommend upgrading to the latest firmware version because 1.12 also fixed some card stability issues.
03-05-2014, 03:57 PM   #3
jerryleejr's Avatar
Well I would, but it won't even read the card to format... As soon as one is inserted gives an error...
JJ
03-05-2014, 04:14 PM   #4
QuoteOriginally posted by jerryleejr Quote
JJ
Format it on your PC in that case. If it's an SDXC card, be sure to use the exFAT filesystem. If it still doesn't work, perhaps the camera doesn't like the card- I've heard stories of certain cards being incompatible (mainly cheap/"fake" ones).
03-05-2014, 04:17 PM   #5
jerryleejr's Avatar
Ok...
03-05-2014, 05:20 PM   #6
Oldbayrunner's Avatar
Use this software to format your card. It is specifically designed to format SD cards on a computer and is much better than using your OS formatting....https://www.sdcard.org/downloads/formatter_4/
03-05-2014, 05:52 PM   #7
calsan's Avatar
Make sure the little lock on the side of the sd card hasn't been bumped.
03-05-2014, 05:59 PM   #8
jerryleejr's Avatar
QuoteOriginally posted by calsan Quote
I appreciate it, but it's any card, and it started with an apparent bad card and hasn't worked since...
JJ
03-05-2014, 06:18 PM   #9
calsan's Avatar
Maybe the contacts are dirty inside the camera? Not sure how to clean this.
camera, card, k-r, kr, memory, memory card, pentax k-r
Memory Card Error with Sony 32GB SDHC Class 10 neiliosis Pentax K-01 60 01-15-2015 02:37 PM
Memory card error notice Tommy Armstrong Visitors' Center 3 09-09-2012 09:50 PM
Memory Card Error and other strange problems? Origineelreclamebord Pentax K-5 13 09-03-2012 10:57 AM
Memory Card Error Pentax K10D Dutch_Member Troubleshooting and Beginner Help 6 04-02-2012 07:46 AM
memory card error problem cdm807 Troubleshooting and Beginner Help 15 10-17-2009 07:22 PM
All times are GMT -7. The time now is 10:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
