06-25-2014, 03:19 AM   #1
K-r problem solved (temporary) by pressing shutter in live view
I have a very weird problem in my underuse K-r. Whenever it is switched on after being switched off after 2 hours, the photo taken is all dark and it seems as if shutter speed is too fast and thus the darkness. With flash on, it helps brighten up a bit but still far from the normal looking photo in normal settings. The above is in looking-through lens mode.
Here is the interesting part, when I switch it to live view, the live scene on the lcd looks like with lots of noise. I will then need to take a photoshoot by pressing the shutter and voila. Everything goes back normal.
May I know what is wrong here?
06-25-2014, 04:15 AM   #2
I've noticed a few odd things happening when the battery in my K-r starts to run low. You've probably looked at that but I thought I would mention it anyways.
Tim
06-25-2014, 05:47 AM   #3
Are you saying that the battery could be old nearing its end of life? Or the battery charge is not full?
My battery is fully charged... But old...
06-25-2014, 07:55 AM   #4
QuoteOriginally posted by Shingkyo Quote
Battery charge not full.
Tim
06-25-2014, 05:42 PM   #5
which could also come into effect at end of life. battery shows "full" but can't provide the required current.
Does the battery die fast?
06-25-2014, 09:17 PM   #6
Deimos's Avatar
I had a weird problem with my K-r where it would seemingly randomly once and awhile produce a very dark image like you describe as if there was a very low shutter speed. Sometimes it would do this a few times and them make images normally again (even with the exact same subject, settings). After awhile I sent it back to Pentax, they took their time with it, when I called them they said they didnt know what the problem was caused by and they sent me a new one. Which I promptly destroyed when falling off a bike. Hello K-5!
Good luck!
06-30-2014, 04:07 AM   #7
Oh dear. Juz to update... It turns out to be battery problem... I put in AA battery case with 4x AA-sized Eneloop, I guess the Sanyo's cell is so strong that it eliminates the problem. I may need to buy new Pentax battery but I guess I will just use the battery adaptor from now on.
06-30-2014, 04:13 AM   #8
Glad to see you solved your problem.
Tim
camera, k-r, kr, live, pentax k-r, photo, shutter, view
K-r, mirror is not going up, no Live View either d1pr3d Troubleshooting and Beginner Help 5 12-19-2016 08:27 AM
K-r : Live View focus, AF & manual madbrain Pentax DSLR Discussion 6 06-02-2012 11:55 PM
Problem with K-X Live View RyudhaPraha Pentax DSLR Discussion 4 10-07-2011 02:26 PM
Problem with k-r live view eldela1590 Pentax K-r 2 07-28-2011 12:45 AM
K-R trouble focusing in low light with Live View using Pentax 18-55 kit lens sportv Pentax K-r 8 01-02-2011 06:42 PM
All times are GMT -7. The time now is 01:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
