01-02-2015, 11:36 AM   #1
Any remote trigger suggestions?
I've read that the Pentax brand remote is pricy, and the battery is not replaceable. Looking to get a remote trigger and wonder who has
had a good experience with one or another model.
01-02-2015, 11:46 AM - 1 Like   #2
Fire Angel's Avatar
If you want something to trigger the shutter remotely using infra-red, then I've had no problems with the cheap Chinese remote I use with my K-r. It can be found form hundreds of eBay suppliers, obviously try to get it from one with a good reputation. There are two buttons, one is equivalent to the shutter-release half press, so it triggers autofocus or wakes up the camera if it has gone into power-save mode, the other fires the shutter. In one respect this item is better than the official Pentax ones; you can change the battery yourself, with the official Pentax remotes you have to send them off to get the battery changed, which is ridiculous in my view.
I'd provide a product link but the supplier I bought from no longer sells the product.
Last edited by Fire Angel; 01-02-2015 at 12:15 PM. Reason: Additional information.
01-02-2015, 11:48 AM - 1 Like   #3
dakight's Avatar
If you have an android smart phone you can get an app, dslr remote, from the Play store. It works great with my K-50 except that the IR beam is invisible to the camera from the rear. You can trigger the camera from the front or right side or you could improvise a reflector of some sort. I suspect the factory remote has the same issue due to the placement of the IR sensor at the front of the camera.
camera, k-r, kr, pentax k-r
Remote flash trigger for Pentax mx and nikon speedlights Josiah Grimmitt Flashes, Lighting, and Studio 6 10-13-2014 07:05 PM
Remote trigger for K mount bodies w/ winder poppaneedsanap Pentax Film SLR Discussion 7 08-30-2013 05:08 AM
Remote Suggestions Ducky13 Pentax Camera and Field Accessories 4 03-01-2013 12:10 PM
Can't use V5 (or other remote trigger) as shutter trigger in hot shoe above 1/180? jake14mw Flashes, Lighting, and Studio 14 07-16-2012 04:14 PM
Remote trigger vs onboard k-x wireless trigger irishwhite Photographic Technique 3 03-06-2011 04:36 AM
All times are GMT -7. The time now is 11:34 AM. | See also: NikonForums.com, part of our network of photo forums!
