03-07-2015, 08:10 PM   #1
Genobreaker's Avatar
Lens Compatible?
Hi. This is probably a stupid question, but does the Tamron 70-200mm f2.8 work with the Kr? On Amazon, they had a little thing where you can check if its compatible and came out as it doesn't, but don't know how reliable is it since it also came up as it doesn't work on some of the higher end Pentax DSLRs.
Thank you.
03-07-2015, 08:15 PM   #2
QuoteOriginally posted by Genobreaker Quote
Thank you.
As long as you get the Pentax K-mount version, the Tamron 70-200mm is compatible with any Pentax DSLR.
03-07-2015, 08:17 PM   #3
SpecialK's Avatar
Absolutely - if it has a Pentax mount. Amazon just is wrong.
03-07-2015, 08:19 PM   #4
sergysergy's Avatar
That lens is available in multiple mounts so you have to be careful with which one is the one they have in Amazon.
03-07-2015, 11:14 PM   #5
Otis Memorial Pentaxian
clackers's Avatar
Works on my K-x, FWIW.
03-08-2015, 08:06 AM   #6
That same lens adviser on Amazon says the Da35 f/2.4 doesn't fit the Pentax K-30?My tip is to go to the manufactures website and verify fit and function.
03-08-2015, 03:12 PM   #7
Thank you everyone. Figured Amazon's lens advisor or whatever called that thing was wrong or it's thinking I'm using a different mount.
camera, compatible, k-r, kr, lens, pentax k-r, tamron
Compatible lens and flash for K30 rdlcud Pentax K-30 & K-50 7 08-19-2013 08:23 AM
New packaging on lens saying full frame compatible? mike.hiran Pentax Full Frame 31 03-26-2013 08:37 PM
K1000 compatible lens? Gillian Visitors' Center 6 11-13-2012 06:19 PM
K100D - Compatible lens? thegrasshopper Pentax SLR Lens Discussion 5 03-02-2012 01:33 PM
Chart of Pentax Compatible Lens TimB5388 Pentax SLR Lens Discussion 4 02-23-2009 09:20 PM
All times are GMT -7. The time now is 01:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
