Originally posted by yophie I have a pentax k-r but when I attached it, no option to change the aperture or shutter speed was available on AF or M on any setting. Why is this happening and what can I do to fix it?!
It is an M series lens, so it cannot be recognized. This lens is what, 30 years old? It was literally made before AF (Autofocus) was invented, before even camera-controlled aperture was around. Looong before digital cameras were invented.
Anyway, switch to M mode, set a static ISO number (not a range), select the aperture on the aperture ring, press green button, wait for the camera to stop down aperture, meter and adjust shutter speed, now press shutter and bam! Photo! The green button (metering) is not necessary, you can just do it by hand if you know what shutter speed is needed, but it is a good shortcut. Of course, you have to set focus using the focusing ring on the lens.
You might have to go into Menu, towards the back of the options, and Enable the Aperture ring use before the camera will let you take photos. And you might have to change shutter priority (not focus confirm priority) if you run into any problems. The camera focus confirm still works and can help you to an extent (little hexagon in viewfinder)
Also, you can read about Catch in focus (aka focus trapping) if you want something similar to AF.
Have fun with your new old lens
It has a nice character to it and it is very compact
