04-30-2016, 02:33 AM   #1
K-r & Helios 44-2
Hello!
I bought yesterday a nearly mint 44-2 (MMZ Zebra - N0069306) mounted on a Zenit B, but my copy wouldn't reach infinity. I had to mod it like Nikon users do by adding a little bit more space between the rear element group and the aperture socket with a small ring of plastic in the helicoid (1mm thickness or so) now it reaches the long end just fine (and it's daaaamn sharp even wide open...i'm amazed, lucky having a good copy maybe, but first shot test are much sharper than my SupTak 1.4@2...)
Wonder if someone had to do such modification to get it work or this is just my copy?
04-30-2016, 04:02 AM   #2
Na Horuk's Avatar
Congrats! My Helios 44-2 is not super sharp wide open, barely acceptably sharp.
What kind of adapter are you using? Are you using the genuine Pentax adapter, or a flanged adapter?
Because "infinity focus" is usually closest to the sensor (and near focus move the elements further from the sensor). So the problem is the other way - if the lens is too far from the mount/sensor, then it won't reach infinity. If it is too close, then it might go past infinity and it might not reach minimum focus distance correctly
04-30-2016, 04:39 AM   #3
Thanks for your return, got an adapter which allows infinity focus (no flange) but not a Pentax genuine. It works well with every m42's i got except this very 44-2.
camera, copy, k-r, kr, pentax k-r
Wanted - Acquired: Wanted: Helios 44-2 Kath Sold Items 3 03-22-2016 08:20 PM
What to buy: Helios 44-2 vs. Helios 44k4 vs. 44m? I am confused Lost Forever Pentax SLR Lens Discussion 16 06-03-2015 05:31 PM
Helios 44M-7 vs. Helios 44-2? tuan2195 Pentax SLR Lens Discussion 12 05-24-2013 12:21 AM
Helios 44-2 (Гелиос-44-2) 58mm f2 preset 8 blades ducdao Pentax SLR Lens Discussion 5 04-25-2010 06:15 PM
For Sale - Sold: M42 Helios 44M-6 MC 58mm F/2 & Helios 44-2 58mm F/2 donTTouchonlywatch Sold Items 6 12-25-2009 02:16 AM
All times are GMT -7. The time now is 11:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
