11-26-2016, 12:57 PM   #1
madison_wi_gal's Avatar
Setting tweaks - best practices?
After messing with various settings (not having read the manual, mind you, but just experimenting since I know the "reset" function will get me out of trouble) I managed to make my K-r shoot multiple frames SOMETIMES while holding the shutter release down. Unintended. It was random and unpredictable. I put in a new battery (to eliminate voltage issues) and it still happened. I just reset to factory and so far it is not doing this, but still testing.
So this leads me to the following: for the *average* / *casual* photographer, is there any advantage to tweaking the default settings (other than Green button, so I can use my SMC 50mm 1.4)?? For example, the AF/AE settings by default are:
AF.A
Multi Segment
Auto 5
And the custom image is Bright
12-03-2016, 02:20 AM - 1 Like   #2
Check the drive mode. Make sure it's set to single frame rather than continuous.
Also, if you want more predictable focusing behavior, I'd recommend picking AF.S or AF.C instead of letting the camera decide
02-16-2017, 02:58 AM - 1 Like   #3
I often use back AF button for AF on my K-r, setting AF.C with auto 5 points while disconnecting AF from shutter button. It allows me to benefit from both AF.S (when I just press the AF button on the back once it works like AF.S in fact) or AF.C (just by pressing the button continously it adjusts for small movements or tracks moving subject). It is also easier to use SR because you can half-press shutter button which enables SR and do not change the focus. Also good when you want to use AF and tripod.
You can find the details here:
Perfect focus everytime - PentaxForums.com
camera, default, k-r, kr, pentax k-r, settings
Lens comparison testing - best practices madison_wi_gal Troubleshooting and Beginner Help 6 10-07-2016 04:01 PM
What camera monitor setting to best view RAW ? BarryE Troubleshooting and Beginner Help 13 12-11-2015 01:01 AM
Best Setting for K3? SonOfMerope Troubleshooting and Beginner Help 7 12-06-2014 05:40 AM
Best Practices: Controlling dust during scanning germar Film Processing, Scanning, and Darkroom 4 07-23-2012 08:11 AM
Is there a "best practices" guide to P-TTL? bdery Flashes, Lighting, and Studio 10 05-23-2011 07:32 AM
All times are GMT -7. The time now is 05:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
