05-17-2019, 07:03 AM   #1
Problem with Pentax A 50mm 1.7
Hi,
I have a problem. I set enable aperture ring but I can't regolate F with my camera. It shows F1.7 on every photo besides I also have tried to change manually F with the ring.
I am a noob and english in not my native language so sorry for the stupid question and errors.
05-17-2019, 07:13 AM - 1 Like   #2
Man With A Camera
Racer X 69's Avatar
QuoteOriginally posted by Oblomov Quote
Hi,
Hi and welcome to Pentax Forums.
What camera are you using? Knowing that might help others understand your concerns, and be better able to help you out.
05-17-2019, 07:19 AM   #3
I use a Pentax K-x
05-17-2019, 07:41 AM   #4
CarlJF's Avatar
Which version of the 50mm 1.7 are you using ? The M, A, F or FA ? If it's an older K-M, aperture can't be controled from the camera, you need to use the aperture ring on the lens.
If it's one of the others, make sure the aperture ring on the lens is set to the A position.
05-17-2019, 07:43 AM   #5
Not a Number's Avatar
Hello and welcome to Pentax Forums.
Please confirm that this is a SMC Pentax-A f1:1.7 50mm lens and that it is on the "A" setting. With the camera set in Av mode the F-stop should be shown in the viewfinder and you should be able to change the setting with the eDial. In Tv mode you can set the shutter speed with the eDial and the camera will select the f-stop.
05-17-2019, 08:18 AM   #6
Yes, it's the "A" version.
05-17-2019, 08:20 AM   #7
Resolved! Thank you all!
05-17-2019, 11:40 AM   #8
Very good, have fun with the lens!
camera, pentax a 50mm, pentax help, photography, troubleshooting
43mm Pentax Ltd vs 50mm Pentax M (1.4) vs 50mm Pentax M (1.7) vs 50mm Sears MC (1.7) easyreeder Pentax SLR Lens Discussion 15 11-10-2014 08:44 AM
For Sale - Sold: Pentax F 50mm 1.4 LN, Pentax F 50mm 1.7 mint in the box, Pentax FA 50mm 1.4 Excellent jjdgti Sold Items 9 05-19-2014 05:48 AM
For Sale - Sold: Pentax 50mm Galore. **FA 50mm 1.7, DA 50mm 1.8 & FA 50mm 2.8 Macro jjdgti Sold Items 9 08-05-2013 04:41 PM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 & K-5 II 39 11-03-2010 06:02 PM
All times are GMT -7. The time now is 01:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
