01-28-2020, 11:31 PM   #1
Pentax K-r doesn't autofocus
Hello,
I've been using a 9 year old pentax k-r. Recently it stopped focusing with af.
When I press the focus button it does activate the motor and try to focus back and forth few times then it stops without focusing.
When I switch it to MF and focus manually, it does beep when object is in focus. So I think af sensor works well.
When I try to focus in liveview mode the visual zooms in but no effort on af motor and it shows red out of focus square.
Lenses does work with my z1-p well.
What causes this problem and can it be fixed?
History about the problem: one or two years ago I bought 50mm and 28mm manual lens with pentax super me and started film fotography and shooting with kr occasionally. Until then I was only using kit lenses 18-55 and 50-200. When I started using those manual lenses it began to cause a problem with my kit lenses. When I put my af lens to kr it started show it as manual focus. Then I tried to unmount and remount it fixed the problem sometimes, sometimes not. Recently I decided to clean contacts with alcohol. However I used 80 lemon cologne as alcohol. It fixed the problem that night, but a day later it stopped autofocusing as I mentioned above. Then I tried to clean contacts again with isopropanol but it didn't help.
01-29-2020, 03:57 PM   #2
Aaron28's Avatar
is the screwdrive exposing itself in AF mode or retract in manual?
01-29-2020, 04:08 PM   #3
ramseybuckeye's Avatar
The manual lenses should not have caused any problems, unless maybe you left the camera in auto focus, the screw may be bent or worse. But the lemon cologne may have caused a lot of damage, I don't know what is in it, but chances are it left sticky residue in the af screw.
04-28-2020, 03:59 AM   #4
I solved the problem. Apparently cologne left some essence oil residue which caused problem. I took a pure isopropanol and a cotton pad. I showed the parts with two red circle on the picture. I pressed isopropanol to these parts with cotton pad and made something like cardiac massage. Pushing in and letting out for a while. Then let it dry and voila. Problem solved.
PENTAX K-30  Photo
af, alcohol, camera, contacts, focus, k-r, kit, kr, lenses, motor, pentax, pentax k-r
Autofocus doesn't work QPaul Pentax Q 3 07-05-2019 10:19 AM
K1 Autofocus Behaviour : Autofocus lock matroxication Pentax K-1 & K-1 II 5 07-11-2018 07:15 AM
K10d doesn't autofocus with Sigma HSM lenses jmbroekaert Troubleshooting and Beginner Help 19 10-10-2012 09:58 PM
For Sale - Sold: FS: Autofocus film cameras and autofocus lenses Not Registered Sold Items 15 03-17-2008 07:08 AM
In-Body autofocus vs In-Lens autofocus Gooshin Pentax DSLR Discussion 7 02-05-2008 11:10 AM
All times are GMT -7. The time now is 02:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
