04-06-2020, 06:43 AM   #1
K-r "sticky" aperture lever, looking for advice
Hi there,
I've had a K-r for nearly 9 years, still works well (it only has a bit less than 15k actuations), excepted the usual stuff (backup capacitor or battery being worn (I have to set date & time whenever I remove the battery), and the original battery just being work as well).
More annoying, when I leave the camera for some days, the first pictures with a A lens are back or awfully underexposed. I traced the problem to be a kind of sticky aperture lever, and I cure that with some seconds in burst mode.
However, there must be a better way to fix it.
How could I lubricate the aperture lever mechanism, as I suspect some grease has gone dry?
Regards,
Guillaume.
04-06-2020, 06:55 AM   #2
Unfortunately it seems you have 'aperture block' failure. Search this forum for the term.
04-06-2020, 07:52 AM   #3
G.T
Hello John,
Thanks for your reply. I've seen some messages with the keywords you gave, I think I'll live with it... That remains a lovely camera.
Best regards,
G.
04-06-2020, 08:49 AM   #4
I am surprised though. Aperture block failure started to be a common failure with the K-30. Are K-r affected as well?
04-06-2020, 09:50 AM   #5
K-r's use the 'white' solenoid, not the problematic green ones.
04-06-2020, 09:51 AM   #6
Not a Number's Avatar
There have been reports of the dreaded green solenoid found on the aperture mechanism of K-r bodies on the German pentaxians forum.
04-07-2020, 03:06 AM   #7
G.T
Being in France, I could have one of these (must be a EU-specs batch), but I don't feel like dismantling mine to check (I've had a look on the Web about that)
06-14-2020, 02:34 AM   #8
No, there were no reports of this kind.
Not in the aperture mechanism, the K-r was the last one using the white Japan-solenoid!
You have quoted those reports before, but google translastion wasn't good enough.
The green China-Solenoid was used for the pop-up-flash in the K-r.
In Pentax cameras sold in Europe Ricoh started to test the green China solenoid (with sucess) in the flash-circuitry already in the K100D, it was to be found in the K110D, K200D, K-2000 (K-m), K-x and K-r:
The very interesting thing was, that some idiots had the idea of exchanging the white Japan-Solenoid of the K-r with a filed/sanded green China-Solenoid.
But then the K-r produces the famous mirror-flap!
All "mirror-flap" K-r's I had on my work-bench missed the white Japan-Solenoid but had a filed/sanded green China-Solenoid built in (of course not factory assembled like this!)
06-15-2020, 11:58 AM   #9
G.T
I think it may worth a reply.
I've dismantled my K-r to find it had a white solenoid (good point), I haven't checked the flash solenoid.
I've ordered a set of Eneloops, as I already had the LR-6 (AA) adapter, it seems the problem has gone. Perhaps the battery (I knew was well worn, after all those years) did not have enough pickup to move the solenoid on a cold mechanism.
Ironically, I may be using my good, old, beloved even, k-r a bit less as I've bought besides a used D5300. But it remains a brilliant camera, well designed, well built and easy to use (especially the menus, compared to the Nikon).
aperture, battery, camera, k-r, k-r "sticky" aperture, kr, lever, pentax k-r
DFA 100 Macro has a sticky aperture lever, who to send it too? David&karen Pentax SLR Lens Discussion 12 06-07-2016 03:05 PM
Rokinon 85/1.4 - Sticky Aperture Lever severalsnakes Pentax SLR Lens Discussion 14 09-02-2014 05:24 AM
Me super sticky shutter, stay's (a bit) sticky crabe919 Pentax Film SLR Discussion 13 07-10-2013 10:58 PM
Good A 50mm F1.4 aperture lever ruined by "vandals", is there a way to cure it? minahasa Pentax SLR Lens Discussion 24 09-15-2011 10:40 AM
Suggestion OBE "Sticky" threads should be "unstuck" MRRiley Site Suggestions and Help 9 08-21-2009 09:09 AM
All times are GMT -7. The time now is 10:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
