Originally posted by photogem The K-x battery is on the front- or backside of the mainboard?
Battery is on the back. You can get to it without unsoldering any wire on the board though you need to undo many of the flexible flat cables, and remove the 4 screws securing the board..
You do need good fine soldering skills manipulating the board to expose the cell to a good degree. The camera with time date cell exposed has rear panel side down so the cell is behind the main board.
Even though it is much a beginners DSLR it is a treat to practice your skills and photographic assumptions with it. I find it helps with use of more expensive gear (Canon 5D 4 example) or shooting film. To me it has been worth while to repair the holding of date and time feature between battery changes or charging. Suffered it for at least a couple of years and it is a pain to reset all the time to me. Hope some of this helps.
