12-07-2020, 12:18 AM   #16
Alex645's Avatar
QuoteOriginally posted by brieck Quote
Thanks for all the comments and suggestions, I do appreciate all the help. Will probably just stick with AA batteries for now as repair is more costly than the value of the camera.
Thanks again all, have a great holiday season.
As they say, sometimes the simplest solution is the best solution.
02-04-2021, 08:19 PM   #17
Closed Account
Michael Piziak's Avatar
I believe the rechargeable AA Panasonic Eneloop batteries are among the best.
02-14-2021, 02:56 PM   #18
Pentax Kr
Camera shuts down (Baterry Depleated) notice with a standard fully charged D-LI109 battery and will not function.
But with 4 Alkaline batteries in an adapter will function fine with no errors.
Anyone have any thoughts on the problem and cure?
Yes, the camera is set to the correct battery type--------
Any help would be greatly appreciated, this is my back-up camera and I was close to scraping it.
Didn't notice question until today:
The powersupply of the K-r was still based on that one of the K-x.
The K-x run with AA's only but the K-r was the first one to use AA's and the D-LI109.
The PS was not stable enough with the K-r which also lead to the problem of mirrorflop.
You can also check what I wrote here:
ttps://www.pentaxforums.com/forums/116-pentax-k-r/399475-battery-type-aa-nimh-eneloop-k-x-k-r-k30-k50-k500-well-ist-k100-200-2000-a.html
i.e. set battery-type in the menu for Li-Ion and then try again.
If it can't be solved, costs for repair would be way too high.
But you have at least one Japan-Solenoid inside your K-r, possibly two!
These are of good value. If you dare DIY, then buy a Pentax K30/50 or K-S1/2 with the dark-image-syndrom
cheaply, repair it as shown here:
Manual solenoid replacement Pentax K30 / Discharge flash-condenser / Solenoid choice - PentaxForums.com
and you have a much better backup body than the K-r!
adapter, battery, battery compartment, battery pack, camera, center, contact, contacts, function, k-r, kr, pencil, pentax k-r, thanks
Pentax Optio E 50 camera connection problem Problem Nat Welcomes and Introductions 2 12-18-2019 08:04 PM
Battery problem or Charger Problem? troika Troubleshooting and Beginner Help 10 10-01-2018 09:59 AM
K-01 battery problem...or maybe not TaoMaas Troubleshooting and Beginner Help 3 07-21-2014 09:43 AM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 & K-5 II 39 11-03-2010 06:02 PM
All times are GMT -7. The time now is 04:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
