Originally posted by cdurfor Humbling..... Especially with Oceana a few days away.... Truly appreciate the Bigma comments... I guess the 300mm may fall short / shy.. Time will tell....
Thanks Chuck. Please don't take my Bigma comments as a discouragement. The 60-250 is only inadequate in situations like this when compared to the Bigma. Its a danged fine lens and it's IQ is awesome and if it was the only long zoom I had, I would shoot the entire show with it and just do a bit of cropping for some of the more distant shots. But when you have a Bigma in the bag all else fails for sheer versatility (if you have good light... LOL). And as for your DA*300... heck, I used to shoot airshows with a Vivitar 300mm f5.6 and did fine. The DA*300 should make great photos. They'll just require a bit of cropping on the more distant shots. Something your gear is more than capable of handling. The main problem with shooting these shows with a prime is that it's real hard to "zoom with your feet" as a FA-18 comes straight at you at 500mph or more. Heck for that matter it's hard to zoom with a zoom when they are coming in like that. LOL
Best of luck at Oceana... Wish I could go.
Mike
p.s. max shutter speed for propeller aircraft = 1/180 sec (lets you get blur in the props). If the props are frozen you might as well have shot the plane on the ground. With some of the newer high performance prop jobs you can sometimes go up to about 1/250sec. For jet aircraft, go with the fastest shutter speed the light will allow.
p.p.s. Pay special attention to the F-22. This aircraft defies belief and with the high humidity typical at Oceana you should get great condensation effects as it makes aggressive changes of direction or is flying at high angles of attack. Same goes for the other fighters, but the F-22 is special!
