Originally posted by kvish I tried taking couple of butterflies in flight. As they move quite fast, focussing is totally messed up. I dont believe lens is an issue (sigma 17-70 which is pretty fast outdoors)
I guess it is some setting that I am missing out
You're not missing a setting - it's just darned hard to catch butterflies in flight! At least with digital you can practice, practice, practice and it doesn't cost anything extra.
Originally posted by kvish I can never seem to get a complete butterfly to focus. I get either the left wing or the right one to focus.
And you probably never will at that angle! Read up on depth of field (there have been a few recent threads on the topic), it's pretty well impossible to get sufficient dof to get the entire insect in focus at a shallow angle. Work with those limitations - the oof areas can be beautiful too, and help set off the area you keep in focus.
Originally posted by kvish The attempt was to focus the head and eye and have the wing motion effect. I cant seem to focus the head though...the wing movement seems to confuse the AF !!
Cool idea! As several others have suggested, try focusing manually. Because of the shallow dof, the slightest focusing error puts the area of focus in entirely the wrong spot. You can also try focusing by moving your body back and forth - it's often much more sensitive than messing with the focus ring, and with such minute adjustments it should neither mess up your composition nor frighten the butterfly away.
The 17-70 is one of my favourite lenses. It's my standard walkabout lens, and I take lots of insect macros with it, although none I can find of butterflies! Watch your subjects, as someone suggested, figure out where they tend to land, and set yourself up nearby. They'll soon consider you part of the landscape. That's what I do with dragonflies. Extra bonus - you see a lot of interesting insect behaviour and come to appreciate them as more than something pretty to photograph. But you do have to be patient. Not so easy sometimes!
Keep practicing, you'll get more keepers as you go along. You would not believe the masses of crappy dragonfly photos I've got lurking on my hard drive! Hm, maybe you would...
Julie
