Pentaxian Moderator Emeritus Join Date: May 2007 Location: Edmonton Alberta, Canada |
You have 3 choices for focus.
1) Manually focus the lens with or without the green light to assist you.
2) Trap focus. Get Screw mount or K mount lenses (with no contacts) and turn the AF switch on. First set up your exposure settings for the scene then adjust the focus while you hold the shutter button down fully. Once the lens is in focus the shutter will fire automatically.
3) Auto Focus lenses. There are a few that may make sense for a reasonable price. The DA 18-55 and 50-200 will give you a wide range with good quality for about $250.00
I would think that if your vision is poor and you have a hard time seeing the viewfinder display that you would want the camera to work in auto settings much of the time. With an AF lens, you can have the camera meter and focus the scene and all you need to do is compose the scene and concentrate on the image you are trying to get. It would make things a lot easier and faster than all the manual settings.
Also you can wear your corrective glasses without much issue I would assume. I do as I am blind in the right eye and have to wear glasses for the left one. You can also get a magnifying attachments for the viewfinder if that would help to see the display settings.
So if you want to try trap focus it will work very well for almost any scene including fast action. It should work with the lens you used for this shot. Give it a try and if you need more advice post back.
