Dilemma ....
Posted By: jankok, 11-22-2007, 09:34 AM
These are two attempts to PP a picture. Which one do you prefer and why? I would appreciate your opinion.
The pics are rather big, so don't forget to press F11 in your browser.
or this one
11-22-2007, 06:19 PM   #2
Mike Cash's Avatar
Please try again. I don't see either image in your post.
11-22-2007, 07:21 PM   #3
JMR
Actually, both photos suffer from under and over exposure. In the first, the highlighted area is spot on, but the person is underexposed. So when you attempted to correct in the second photo, the Highlight became overexposed and the person and shaded areas became closer to an accurate exposure. What to do? The only thing I can think of to mask areas and create layers, where each area is rendered with a correct exposure and then flatten (combine) the image. But this a long and complex process and that is why few people beyond professionals do it.
Too much work.
JR
11-22-2007, 07:32 PM   #4
QuoteOriginally posted by Mike Cash Quote
Here's the links Mike.
pic 1
pic 2
for some reason Firefox says they're Forbidden, but they opened in Internet Explorer for me.
jankok,
I tried to fix them with traditional methods, but I just couldn't lighten that over exposed area enough.
So I did a major Vignetting job on it to give it this look.
Someone might have a better idea.
11-23-2007, 05:49 AM   #5
Sorry, this is my first posting of embedded pictures in this forum. I must figure it out how to do it. When I previewed them they showed fine, but now they're gone and only the text remained (browsing in FireFox 2.0.XX).
Perhaps someone out there knows a solution - how to embed images from Pbase in this forum?
Anyway - before I figure it out, here are the links:
Sleme_071007-090426_J_R01.jpg photo - Janko Kernc photos at pbase.com
and
Sleme_071007-090426_J_R02.jpg photo - Janko Kernc photos at pbase.com
11-23-2007, 06:24 AM   #6
Thanks for finding a way to get the pictures. I'm using only FireFox and can't see them in my post at all.
I don't know what you see on your monitor, but in the picture in your reply all the yellow and green colours are gone. The picture is mostly light brown and foggy without contrast. I verified this on two separate systems: one (roughly) calibrated CRT monitor and another one with an uncalibrated LCD monitor. The result is similar in both.
Perhaps you could run the programs QuickMonitor and QuickGamma from this page:
QuickGamma
and follow the instructions on your system. This is an easy and inexpensive way of roughly calibrating your system.
I don't think the pictures have many under/over exposed parts. Please check the histograms of both pictures for R, G, B channels and lightness.
Only the second picture shows some underexposed areas (backpack). Overexposed areas do not show in histograms.
If you see overexposed areas on your screen, then your monitor and graphics card settings should probably be adjusted.
For histogram checking you can use PhotoMe (PhotoME - Exif, IPTC & ICC Metadata Editor) or FastStone (FastStone Image Viewer - Powerful and Intuitive Photo Viewer, Editor and Batch Converter) viewer programs.
11-23-2007, 06:30 AM   #7
QuoteOriginally posted by JMR Quote
Too much work.
JR
Hi! Thank you for viewing and commenting my pictures.
The difference between the two pictures is only slightly different contrast settings and a few other small adjustments in the RAW converter.
11-23-2007, 10:37 AM   #8
Hi Janko
Much prefer the second image. And I don't think the forest part is overexposed (getting close to it but you stopped short enough) I think the first shot the shadows are a bit too dense and too much detail is lost. BTW I am using IE and am having no problems seeing the images (including stu's strangely colored one).
NaCl(thats my story and I'm sticking to it)H2O
11-23-2007, 03:59 PM   #9
QuoteOriginally posted by NaClH2O Quote
Hi Janko
Hi, SaltWater!
Thank you for your comment. It is an interesting one. In the last year I have learned quite a lot about how a picture appears on different display devices.
On my display (still a good old CRT) both images appear quite similar. The second one is a little bit more contrasty, but especially in the bright to medium portions shows a bit less detail than the first one. On the other hand, the first image, while showing some more detail, looks a bit flat and that's my dilemma.
But probably quite a lot depends on the display device used, and how it is calibrated.
11-23-2007, 07:24 PM   #10
Heinrich Lohmann's Avatar
Janko, here is what I would do:
Heinrich
11-24-2007, 03:04 PM   #11
Thank you, Heinrich! You did a very good correction to both pictures. They appear more balanced than the pics I posted. Only the second one seems to me a bit too saturated.
How did you do it?
11-24-2007, 03:55 PM   #12
Hi Janko, I opened them in PS PS3 Raw, adjusted curves a bit, in PS a little shadows-highligt, a quick burn in the shadows and a tiny bit USM.
In the 2nd one I added color correction and increased saturation (before USM). I over saturated the second one purpose just to show what can be done with a difficult image.
If one would take more time and work with adjustment layers the images could be further improved but Ii just did a quick job on them.
Heinrich
11-24-2007, 06:33 PM   #13
Too much work.
JR
Whether or not their just at or over the line for under- and/or over-exposure, I'd agree with JR that one has places that are too dark, and the other has pushed the limits (for my tastes) on being too bright.
I will disagree with him however about layering being too difficult. Here's my attempt from layering your two versions using a mask (and the paintbrush tool) to bring the darker version of the forest back up. I used a slight levels tweak to your brighter version, and then desaturated the yellows and reds a bit on the flattened version. It took just a couple minutes and I am far from a professional at this.
11-25-2007, 03:06 AM   #14
Hi, Heinrich!
Your and betsypdx's editing made me try again. My two originally posted pictures were directly output form the raw converter, without editing in a bitmap editor (i.e. a PS type program). Now I took the two pictures as posted and tweaked them individually in PSP X and then joined them into one picture using layers and some masking. Here's the result:
11-25-2007, 03:13 AM   #15
Hi, Betsypdx!
Thank you for your edit. On my monitor it appears a lot better than my originals, but the dark parts are still a little too dark, and the sunny part of the wood lacks a bit of "sparkle".
Your editing explanation gave me the idea to try again using (as you did, if I understood correctly) my both jpegs as input layers for the edit. Thank you!
The result is posted in my reply to Heinrich above.
camera, photo
dilemma of what I should get/keep... chaude Pentax SLR Lens Discussion 10 11-02-2010 03:15 PM
Dilemma Substitute Pentax DSLR Discussion 12 08-25-2008 06:51 PM
My dilemma... jmdeegan Pentax DSLR Discussion 25 08-01-2008 04:27 AM
I have a dilemma... drevilsmom Pentax DSLR Discussion 5 05-26-2008 06:54 AM
Dilemma, dilemma ... Bronco Pentax DSLR Discussion 31 04-15-2008 05:39 PM
All times are GMT -7. The time now is 04:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
