Originally posted by chookfarmer Thankyou all for your feedback. I was programmed in AV mode and let the camera set the shutter itself. Little Laker I would be thrilled if I was after the "old style", however I was trying to just get a shot that was within a bulls raw of what some of you guys produce.....
I was at ISO 800, what would you have used?
Hey Peter thanks heaps for your time, I think I follow what you are saying. I will give it a go and see how I fare!!
LL, I love what you did with Peters shot. If you dont mind can you explain the process for us beginners?
Many thanks
CF...
chookfarmer, I'm not sure if you are using as post processing program and there are several different freeware versions that many use here. I use Paint.net which can be found here:
Paint.NET - Free Software for Digital Photo Editing I like Paint.net because it has a good forum and tutorials to learn the program. But it is very intuitive.
This will allow a lot of the things that both I and Stu did to the shot. The top of the line program is Photoshop CS3 but it's expensive and for a hobbiest, most of these freeware programs will do many of the same things for little or no cost.
As for the ISO to shoot. use the lowest possible setting you can get away with.
Now there is a solid rule of thumb that you should follow as much as you can. "Shoot for the focal length of the lens". Now Shake reduction and good shooting technique can give you 3-4 stops extra (lower shutter speeds). So that means if you are using a 300mm lens you need to shoot at 1/250th or above. More than that for landscape work is not necessary. Higher shutter speeds would be used mostly if you were trying to capture a fast moving subject.
So now that would have given you much more flexibility to adjust the camera. You can get a smaller (larger number) aperture setting which will give a greater depth of field (more of the scene in focus). Then you can use a lower ISO setting which will give a much sharper image. ISO is the sensitivity of the recording medium (film or digital sensor).
The higher the ISO the more noise that is added to the image. The lower the ISO of course the less noise.
