Originally posted by hamidlmt Brilliant timing! You should break stuff more often!
That is the plan! Thank you Hamid and you will be seeing a lot of broken stuff online here soon,
Originally posted by blwnhr Spot on. I love the texture in the water on the second shot.
Thank you and those textures are the vibrations caused by me just missing the center of the glass with the golf ball.
Originally posted by Kro77 Very nice work, could i ask did you do a continous shooting method or was it one shot. Also I was wondering what flash you used for this?
It was in continuous but it wont work since High-Speed flash sync pretty much drains the flash in one shot and it'll take a second to charge back up. On these I used the Pentax AF540 which bar none is the best flash for the money, but I also have a backup to it, an AF360 and a newly released Promaster 7500EDF that can be upgraded if P-TTL2 rears its ugly head.
Originally posted by JCSullivan Chris, hopefully you were wearing safety glasses and had a filter on the lense.
Otherwise the broken glass is excellent - mind you would have prefered a little more light.
Well done
No to number one and yes to number two
I modified my lite tent to have a trap door on the roof and I dropped the glass through it and only the tip of the lens enter the light tent through a small port hole in the front so I was protected my a millimeter of fabric! That was a lot of light, but not so much for that light to reflect from since it's well, glass!
Originally posted by Romoman How fast are you syncing? Flash on camera or off?
The glass I believe was 1/2000 of a second, but the EXIF is attached if you'd like to double check me.
Flash off-camera using the Pentax Sync Cable and Off-shoe adapter, which are expensive, but worth the money you spend since they destroy a standard TTL cable.
