Originally posted by MSL
The first is a white sheet of paper, the second a black sheet of paper
And this is supposed to make me feel better
That said from what you have indicated he is using a dedicated macro lens - something I still don't have. Sunlight yes - but also horrible winds that have made macro shooting a real pain.
eaglem's images always impress me - macro done well whatever tools are being used
I frankly used tubes long before I had a dedicated macro. I used tubes with just a standard 50mm 'normal' lens back in the film days.
The critical 'correction' that is documented for macro lenses doesn't matter for critter photos. The correction that is specially made
in macros is for 'flatness of field'. as you know the DOF is pretty skinny in macro stuff--- and using a non macro lens it can
be such that getting something like a postage stamp in focus all the way accross is not possible because the 'in focus' field isn't flat.
Unless you step on them first bugs aren't flat either so that really doesn't matter much.
Beyond that--- using a longer lens (like the 100mm) has a tactical advantage for some types of macro photography because
you can get further away As you know 'lots of light' is helpful, and when the camera lens is 1" from the object you are photographing it is fairly easy be the shadow that is making the picture too dark. If you are taking pictures of things that jump, bite, move, sting, fly away, etc. the close proximity increases the likelyhood that they will do some of the above before you get the photo.
I think many macro photographers (certainly including yours truely) don't use AF or even MF when focusing on a object....--- we simply
set the lens to the magnification we we want, and then move the whole camera forward and backwards until the desired thing
comes into focus.... Consequently whether you are using a tube or a lens with a long helicoid matters not.
Indeed some the first macro photos I took, I did just to prove I could because a friend told lme I could--- I had no macro equipment.
but I took a toilet paper core--- reduced the length of it to 2 or 3 inches, took the normal lens off my camera and with a lot of hands
held the lens on the end of the toilet paper core and then the core against the front of the camera. It's actually not as hard as it seems
