There are a few things that you should consider before chucking your extender... which I do not recommend you do BTW.
First: You need to be aware that even with the very best dedicated extenders there is going to be some degree of image degradation. To counter act said image deficit you need to consider stopping down the lens at least a minimum of one stop to recover some sharpness.
Second: If your tests are not shot on a tripod the results are spurious at best. Use a tripod and keep track of your f-stop and exposures. Bracket the image and compare those images to find the sweet spot when utilizing the 2x
There are no free rides in photography. For everything you gain, you lose something. In this case, you gain focal length and lose f-stop or shutter speed. Also, recognize that a 2x will never be as sharp as you want it to be and you will be a little happier
Stephen
